regear or not to regear a 2012??? Here's the answer
This thread has been very informative!! I've decided to go with the 4.56 gears on my JKU sport Manual with 2.5 lift and 35 in tires.
Now, I've looked on the vendor forum and could not find many deals or posts about gears. Where and what brand of gear is good to get? And is it worth it to get the ring and Pinions gear set? Lastly, what kind of pricing am I looking at for just the gears (Not install)?
Seems the install price varies alot depending on shop!
Thank you all for your help and posts, it has helped a noob like me learn tons!!!
https://www.jk-forum.com/forums/uplo...o-chart-12.jpg
If youre going with 40's I guess your building this mostly for rock crawling. It say 5:38 or 5:86. I would ask around however because I have 0 experience as to how accurate this chart is when it comes to seat of the pants performance for tires that size.
First off, I'm fairly new to jeeps, this is my first one, and as a side note I'm in love. I have a Manual 2012 JKU Sport with 3.21s. I've added quite a bit since I purchased in April. I'm now running GY Duratrac 315/70/R17s, LOD Shorty front and rear with tire carrier, LOD rails, EVO oil pan skid, and a Superwinch (lot of weight total) on a Rock Krawler 2.5 Max Travel. I remember researching this topic prior to adding my lift and decided just to get all my mods on before pulling the trigger on a regear, because like most of us not in CA, the prices are definitely not under $1K, particularly with the 3.21s because a new carrier is needed.
Since adding all the mods, I've definitely noticed it's more sluggish than it was stock, but it's something that I can live with. In very rare cases during normal driving, I have to work the clutch a touch more to get going, like on a large hill, etc. but I've come to terms that it's something that I can live with. Yeah the Jeep is a little slow to get going, but overall I'm fine with it for daily driving. I recently did a wheeling trip at Uwharrie, where I was in 4 low most of the time, but I felt that while in 4 low, the power/gearing/pep was incredible. I was crawling over the hole park and never really had a problem. This may be a dumb question, but after adding everything and driving around a lot, I still haven't figured out a justification as to why I would need to regear? Is it just to get the stock performance back while in 2wd? Are the gains that much that it's worth justifying ripping out perfectly functioning stock gearing? I honestly believe if I had 4.10s I would be completely fine, but I'm curious as to what other jeepers have to say when it comes to the driving factor that's telling you all to regear?
By the way a new carrier for the D30 is like $80. You're not looking at too much more than $1k if you're just doing gears either. Maybe like $1500 if you're getting boned on the labor.
Question, i have a 2012 jku with 3.21 and an auto. Im planing to get a 18x8.5 enclosed trailer for landscaping. what gears do you all recommend for that? It will be about 7k lbs with the trailer and the gear in the back max.
you are gonna want to go up in gears, but it depends on the tire size you are running on the Jeep. If you are keeping stock tires I would suggest 4.10 minimum, but prob 4.56. This will give you the torque you need to get the trailer moving. If you are going up in tire size than that is another story. Thats a heavy trailer for a JK. I'd go up at least one above the normal setup for the tire you choose. Like 4.56 for stock 32" or 33", 4.88 for 35", 5.13 for 37". This would be a bit high for normal use, but nice to haul a trailer.
