removing shift knob
Old Apr 28, 2007 | 05:10 PM
  #21
SrfrGrl's Avatar
ha ha that might look better in a hummer! actually i wanted to put a billet knob on but i havent found any press on shifters aside from the rock knob.
Old Apr 28, 2007 | 05:21 PM
  #22
G16's Avatar
G16
Litegrip.com is working on a billet push on knob (no threads) for the JK. Talk to John.
801 546 1375. I ran into John in Moab a few weeks ago.
Old Apr 29, 2007 | 12:18 PM
  #23
SrfrGrl's Avatar
Thanks, I'll definitely check them out!
Old Oct 6, 2007 | 07:05 PM
  #24
gldwings1's Avatar
Here's the deal from someone who has done it. I posted the post everyone is talking about. I have a universal T handle B&M, don't believe it! So your pull the top half of the shift knob from the body. Use something thin to go between them at the seam. Then there is another lower seam below where the shift lever inserts into the center of the knob, pry that lower trim ring from the bulk of the shift knob, pull the shift knob straight up on the lever. The lever has a notch about an inch long on one side. It is not threaded. I have not been able to find a shift knob that is large enough for the factory lever. Please pm me if you find one.
Old Oct 8, 2007 | 12:11 PM
  #25
Originally Posted by putnam dan
Anyone got a pic of a rocknob on a JK?
I have the hand grenade from Rocknob, does that count?
Old Oct 18, 2007 | 08:21 AM
  #26
mizedog's Avatar
Does anyone have the diameter measurement for the manual tranny shifter shaft, and the t-case shaft? I'd like to supply that to Flameball to see if their spline adapter will work. Thanks.
Old Oct 18, 2007 | 09:21 AM
  #27
bahadden's Avatar
Default shift knob
yes it pulls straight off, i am working on a 7 ball shifter i drillied a hole half way through and taking messurement for a set screw to fit into the grove at the top of the shifter. ill let you know how it turns out. oh yeah the t case knob comes off the same.
Old Apr 17, 2008 | 02:30 PM
  #28
G Timmy's Avatar
anyone found any good shift knobs that are push on?
Old Jun 6, 2008 | 05:29 AM
  #29
windsor40's Avatar
Default Custom Shift Knob
I placed a towel around the shaft, then attached a channel wrench just under the shift knob, then hit it gently with a rubber mallet...... and it popped right off -- no problem.
Then I had to drill a hole in the bottom of that custom knob. hole was a hair over 1/2" wide and I made it it 1.5" inches deep. fit very tightly on.
I also painted the lenses green to match the exterior.
Name:	Shift knob 1.JPG
ID:	9830   Click image for larger version
Name:	Shift knob 6.JPG
ID:	9831   Click image for larger version
Name:	Shift knob 4.JPG
ID:	9832   Click image for larger version
Name:	Paint Base Coat 3.JPG
Old Jun 6, 2008 | 05:55 AM
  #30
SASQUATCH's Avatar
Back when I did my bodylift I was amazed that a 12" Crescent and tapping with a small hammer popped both of these into my back seat with ease
Great helpful post.
