Rock Slider / Rocker Protection
Old May 15, 2019 | 09:38 AM
Ajkaz's Avatar
LOD Signature Series have the perfect setup for excellent protection and a functional step. The mounts are very stout and can be bolted to the frame. I didnt want to do a bunch of drilling so I bolted the few factory locations and then welded the rest to the frame.
Old May 15, 2019 | 09:51 AM
Erok's Avatar
Originally Posted by tjkamp
You should look into White Knuckle Offroad ( https://white-knuckleoffroad.com/jeep-jk/ ). Rock sliders are the only thing they make. They are made to order, bunch of different options and bolt/weld to the frame. Love mine, have taken the full weight of the Jeep coming down on obstacles no problem.
Can't say enough good things about them.Attachment 677371
I second this. I love mine and they absolutely have taken the weight of my JKU on rocks. I priced all the competitors and these guys won for me.
Old May 15, 2019 | 04:24 PM
tjkamp's Avatar
Another bonus of the frame mounted White-Knuckles is no need to also buy rocker armor. The pinch seam is pretty well hidden, if it bothers you (doesn't really bother me), and if you manage to damage a rocker with these installed, in pretty sure that means you totaled the Jeep in the process, so you will be having bigger issues than a wrinkled rocker.
They do, or at least they used to, make a little strip of metal to cover the pinch seam, but I never saw a need for that.
Old May 17, 2019 | 12:54 PM
Erok's Avatar
Exactly this. I can't see the benefit of rocker armor IF you have a solid frame mounted set of sliders like this. Pinch-seam mounted ones, I can understand, but like tjkamp said, you'd really need to mess up to damage the lower part of your Jeep with these on.
