Rubbing on full flex
Old Sep 25, 2013 | 08:58 AM
  #21
Ncb's Avatar
Ncb
Originally Posted by familytime
Not to change the thread,but how not having more lift not fix the rubbing problem Bump stops will control up travel
So let's say the tires are rubbing with two inch springs and the current bump stops. Adding a 3" or 3.5" spring will increase the height but the axle will still travel until it hits the bump stop.
More lift and extending the bump stops together can remedy rubbing.
OP doesn't want to extend the bump stops.
Old Sep 25, 2013 | 01:05 PM
  #22
Scruff's Avatar
Having re read my posts I am a bit unclear sorry.
The front tyres are rubbing both sides when on full lock turning. This rubbing is on the chassis.
As I said earlier as the lift is small I dont want to bump stop much more.
I have attached a pic.
Thanks all for your comments
Old Sep 25, 2013 | 01:07 PM
  #23
Scruff's Avatar
If I change offset I will need wider flares as the guards won't cover tyres which the police are all over where I am.
What is the widest flat flare?
Old Sep 25, 2013 | 01:14 PM
  #24
Mark Doiron's Avatar
Originally Posted by Scruff
...The front tyres are rubbing both sides when on full lock turning...
Follow the procedure at the website I posted earlier so your steering wheel is slightly more limited and you should be fine.
Old Sep 25, 2013 | 01:18 PM
  #25
TheDirtman's Avatar
If it is only that much rub when wheeling I would leave it alone and not even worry about it.
Old Sep 25, 2013 | 01:48 PM
  #26
Scruff's Avatar
Thanks guys. I also noticed that slight rub on the road when at lock so ill try limiting the steering.
Old Sep 29, 2013 | 02:12 PM
  #27
Scruff's Avatar
Did the steer stop adjustment and seems to have solved it. Thanks all for the tips
