Rubi lockers
Old 12-13-2013, 02:58 PM
livewire0212's Avatar
Default Rubi lockers
Are the other wiring on the stock lockers for a rubicon for speed sensors??
Old 12-13-2013, 03:08 PM
ronjenx's Avatar
Not sure what you are asking, but I'll give it a try.
The Rubicon locker has a harness connector for the locker power, and a harness connector for the locker position sensor.
Old 12-13-2013, 07:16 PM
Ok!! I have a unlimited & I just installed rubicon axles with lockers on my unlimited I was wondering what the other wires were for??
Old 12-13-2013, 08:39 PM
karls's Avatar
The only extra wires your Rubi axles will have over stock axles would be a locker engagement confirmation sensor (whatever it's called) and potentially a power wire for the engagement....or are they air like the old Jeeps?
You've got speed sensors on your current axles.
Sent from my DROID4 using Tapatalk
Old 12-13-2013, 08:46 PM
ronjenx's Avatar
Here is a thread that will answer your question: https://www.jk-forum.com/forums/stoc...-study-263666/
Old 12-14-2013, 04:50 AM
karls's Avatar
Well there ya go, thanks Ron. I get to learn something new every day.
Old 12-15-2013, 03:13 PM
eumel789's Avatar
Cool
Maybe this helps :-)
ID:	517031   Click image for larger version
Old 12-16-2013, 05:32 AM
That helps a lot thank u!! Im not sure if I need anything going to the lock actuator??
Old 12-16-2013, 05:33 AM
[QUOTE="livewire0212;3785562"]That helps a lot thank u!! Im not sure if I need anything going to the locking sensor??
Old 12-16-2013, 05:34 AM
[QUOTE="livewire0212;3785562"]That helps a lot thank u!! Im not sure if I need anything going to the axle lock sensor??
Quick Reply: Rubi lockers
