snorkels... pros & cons
Think about Duck Taping doors and vents closed.
I did 24" water crossing once and took 2 weeks to get mildew smell out of my 13 JK.
I still have not found where water got in.
Most dudes I know that have Snorkels don't touch water. Kinda weird.
I have Banks intake.
Ernie
Ernie
Yet, a snorkel is an asset where I offroad a lot, and where water is hard to find -- in a desert.
Thick dust, my friend, is a very good reason for having a snorkel.
A small leak is not something you could not see even if the whole snorkel was external.
The answer to that is proper installation and the use of sealing material. When done right, there are no leaks on any snorkel, the RR included.
Branches and snorkels aren't on good terms with each other, so they should better be separated...
The RR is well protected, and the exposed part is tucked in more than the AEV.
Originally I was going to get the RR snorkel and called Northridge, he talked me out of it saying they had a bunch come back and no longer carrys them, so I went with AEV
So, what derogatory words do they have about each and every RR product, besides the snorkel? ...
Researches have shown that badmouthing the competition is the opposite of good advertising strategy...
The AEV has under the hood connection, exactly like all snorkels, connections which you don't see from outside.
A small leak is not something you could see even if the whole snorkel was external.
The only under the hood connection is where it connects to the airbox which is one connection and once sealed, is the only one that would need to be inspected when changing out the air filter.
The RR one has the same, plus another connection under the battery area which good luck inspecting with ease, and a drain nipple in the fender.
My AEV has taken quite a few hits and the thing is rock solid.
I tend to believe that prevention is a better way than frequent inspection.
Haven't heard complaints form people who correctly installed and used a sealing material.
Failing to do that isn't good for any snorkel, even the mighty AEV.
That is true, any item will break at one point or another. I find the AEV more secure for the bushy trails we have up here as it doesn't have a joint at its base and only one nut holding it to the a-pillar. Severe pin striping and dents are unavoidable once you get into the mountains here and I feel pretty confident about how secure it is.
Same reason you see all BAJA trucks run snorkels......wait they don't.
Goodluck with your choice.
Shit I forgot, camels are kind of built in snorkels, so yes its a good idea for desert.
Ernie
I also think my AEV will hold up well to just about anything I intend the throw at it. I could probably stand on it, but since it's new, that'll have to wait. I agree with Vlad on that the AEV would be easier to inspect since there's only one connection if you don't count the ram air at the top. It's already taken some good tree branch abuse and has the scratches to prove it
So, you don't know that some of the Jeeps drive through dense sand dust, and you don't know that snorkels prevent plugging the air filter with fine sand?
Google for it...
Or join me for a few days, in the right season, in the desert...
BTW, where do you see a snorkel on that JKU Sport? ...
Baja trucks are not meant to be long lived. They wouldn't benefit them enough for their engines' short lives.
Personal attacks on another poster, instead of addressing the issue, usually come from posters who don't have a clue, and instead of asking and learning, they try to mock... which looks silly.
Google for it...
Google for it...
I have not been Safari Hunting, but I know a guy that does is for a living and they have some insane rains storms. He actually buried a Range Rover, it did not have a snorkel.
It probably could have used one.
Like I said, whatever excuse you need to sport your snorkled Sport.
Good luck with you purchase. I'll try to find pics of all my rides......all snork less. Except for the STI is had a scoop for intercooler. I digress.
Thanks for the invite, I'll pass on the desert. It's kind of chalking and dry, reminds me of work. I prefer Cabo San Lucas beaches and Baja trucks.
Ernie
