SOLID Front Axle Hub Conversion Kit - Available & Installed!!
Old May 3, 2008 | 06:17 AM
  #51
BLKRUBI's Avatar
Originally Posted by Piginajeep
you can always run 3 wheel drive with a hub kit
Serious question. I not knocking it either, but can't you do that now if you have lockers. I know it maybe better or easier with manual hubs, but isn't it possible now?
Old May 3, 2008 | 07:32 AM
  #52
2K1TJ's Avatar
Originally Posted by Cruiser
Remember the fullsized dodge ram 2wd truck uses 5x5.5 wheels,, the steel 16" rims on the j8 were from one of those,, and the factory mags off those trucks are plentiful in the yards,, I'm planning this swap when I get my 44 front axle for my x.. Then I'll epgrade the rear axle shafts at the same time..
Would be nice if there was a set of axles to buy already converted to 5x5.5 with the hubs on front and rubi lockers for bolt in,, buy the time I get to do there there will probably be 60's out,,
Yeah, so did CJ's and older full size 1/2 ton Fords. Good selection of wheels in this pattern.
Old May 3, 2008 | 12:28 PM
  #53
Piginajeep's Avatar
yes you can, But what else are you going to destroy in the diff with the broken shaft spinning...
Old Feb 10, 2011 | 10:52 AM
  #54
xj2000's Avatar
I am digging up an old thread because I can't find what I am looking for when I search. What is being done to the rear? New axles for 5 on 5-1/2? If I change axles what do you do with the roters so they fit with this hole spacing? Machine?
Old Feb 11, 2011 | 05:22 PM
  #55
nthinuf's Avatar
Spacers, or people are recommending the Ten Factory shafts since they are drilled for both patterns.
Old Feb 13, 2011 | 06:15 PM
  #56
BKGM Jeepers's Avatar
Are the SOLID conversion kits still available? My JK runs 5x5.5 already I have been debating between a built 44 with these hubs and a built 60. My math puts (I already have a Rubicon so I have a locker that's already geared too). I'd need shafts, the hub kit and a beef up kit for the 44. The beef up kit is 1200 installed and the hubs are about 1200. The shafts and u-joints are about 600. That would make me right at 3K for my front. A new 60 is about $6K. So this process would be about 50% the cost of the alternative.
I do like manual hubs. I've converted all my previous jeeps.
The problem I had was actually finding the SOLID kits.
Old Feb 13, 2011 | 09:42 PM
  #57
nthinuf's Avatar
$1450 on their website
Or look at the list of dealers, there are 10 in California.
Or PM northridge and see if they can help you out.
Old Feb 14, 2011 | 08:09 AM
  #58
xj2000's Avatar
But one of my questions is....what do I do to put my rear brake roters back on when my Jeep goes to the 5 x 5-1/2 bolt pattern?
Old Feb 14, 2011 | 08:30 AM
  #59
Bustabizz's Avatar
Former Member
Originally Posted by xj2000
But one of my questions is....what do I do to put brake roters back on when my Jeep goes to the 5 x 5-1/2 bolt pattern?
Call and talk to Matt at Solid, he has answers, he designed the system. You need to have a machine shop bore the rotor center out and redrill the holes.
Old Feb 14, 2011 | 04:24 PM
  #60
I recall seeing the center machine requirement in some original on-line posts. The work is pretty cheap at a machine shop.
