Stage I thoughts/ideas need a lil advice
Old May 27, 2011 | 11:08 AM
apeezee's Avatar
Originally Posted by renpia
I would def go with front lowers. The rear is up to debate for me. I went with lowers in the rear and I have zero issues with handling or pinion angle issues. Others will say go uppers in the rear. I think it may depend on 4 door vs. 2 door.
Hmm ok, it will probably be a last minute decision when i order from dave at northridge. He should be able to steer me in the right direction i would imagine.
Old May 27, 2011 | 11:11 AM
renpia's Avatar
That would be a good call.
D_engel's Avatar
the 5.38s seem a bit steep for 35's. Maybe some 5.13's instead?
Old May 27, 2011 | 11:13 AM
renpia's Avatar
This has been covered to death. For auto's many recco 5.38's with 35's. If I had a D44 up front I would go with 5.38.
apeezee's Avatar
Yea, this is my other area of conflict. I guess im just planning ahead because i imagine i will want 37s eventually. Would it be better to jump to 5.38s now or 5.13s and deal with the 37s when that bridge comes?
Old May 27, 2011 | 11:15 AM
renpia's Avatar
If you think you will go 37's stick with 5.38.
Old May 27, 2011 | 11:24 AM
08yellowx's Avatar
Being a rubicon, you already have 4.10's I would wait and see how it performs before the gear purchase ( there's always 4Lo) I have no complaints with mine on 35's and 3.73's and I'm at 5000 feet or above most of the time.
Old May 27, 2011 | 11:28 AM
apeezee's Avatar
Not a bad idea, i can always get them put in later.
Old May 27, 2011 | 11:45 AM
08JKRHD's Avatar
I just put this lift on without adding control arms. Many people run the kit only without changing CA's. I'll go with lower CA's first if the need develops. I would suggest going with high end shocks since it is your DD. I got the Fox racing piggy back reservoirs in the front and the 2.0 fox shocks in the back. The ride with these shocks is much better than other shocks which I consider important on a DD.
Old May 27, 2011 | 11:52 AM
apeezee's Avatar
From what i have read the ride is pretty good when using the shock adapters with the rubicon shocks. Either way, i can try it with the rubi shocks and then go from there. I dont see the need to jump into crazy shocks just quite yet. I know that Bilstein 5100s are in my future in sure but for now my research has shown the Rubi shocks should be just fine. As for the CAs, i think i might go with front lowers to start and go from there.
