Steering issue
That may be some of the problem with the sector shaft screw in the box. Adjusting those is usually a recipe for other trouble. Contrary to popular belief worm gear steering boxes are not adjustable. That screw is for factory or rebuilder setup and should be left alone forever by the owner. Try backing it out about 1/2 turn at a time and go for a drive. If it works and steering wheel has excess play then plan for a new or rebuilt steering box.
Been out of town so have lost track of this thread a bit, but it is totally safe to drive with no SS. If all is good with the jeep you shouldn't notice any difference at all. Many people drive without a SS 100% of the time.
If you back out that sector shaft adjuster too far then the steering wheel will become quite sloppy with a fair amount of play. If you have come back more than 2 threads then you have gone plenty far enough. Normally that adjuster will not go down into the box more than about 1 turn anyways before you start forcing it which is not good.
