Steering Shake
Old Mar 24, 2009 | 11:42 AM
  #21
JK-Q8's Avatar
Originally Posted by jayrav
WOL beat me to it
but my jeep has on 20000miles. how can i be burning ball joints?
Old Mar 24, 2009 | 11:44 AM
  #22
Hellbound13's Avatar
FWIW my balljoints went with only 6000 miles on them and my steering box at 12K.
Im told its a Jeep thing.
Old Mar 24, 2009 | 11:45 AM
  #23
JK-Q8's Avatar
Originally Posted by Hellbound13
Side to side means your tie rod end is shot.
il check that later on, but i still dont know what the ball joints are, sorry. if i jack one wheel up and then move it side to side and up and down and it moves that means i got bad ball joints?
Old Mar 24, 2009 | 11:46 AM
  #24
JK-Q8's Avatar
sounds like you beat the hell out of ur jeep? i dont but i wish i could. wouldnt afford the repairs. heheh
Old Mar 24, 2009 | 11:53 AM
  #25
jayrav's Avatar
Originally Posted by JK-Q8
but i heard that the DW is not because of lifts. how come i got the shake right after installing the lift? you mean check the alignment and whats the road force balancing?
A road balance machine (if I'm not mistaken)what it does is balances the wheel like if it were on the ground. It sort of has a roller which applies pressure(force) to the tire and the machine indicates where each weight goes on the rim, not bunched up like on traditional balancing machines.
Now, as for the ball joints. Sorry I don't have any pics for you, but if you follow each end of the tie rod you will find the part that connects the tie rod to the knuckle. That my my friend is a ball joint(2). Now if you look for the next metal rod that connects to a thing that looks like a automotive window handle to your upper right as you are looking at the front end to the jeep. There you will also find 2 more ball joints on each end. There is one more ball joint that I'm aware of on the passenger side just below the last one I mentioned. That is a total of 5 ball joints.
Hope this helps
Old Mar 24, 2009 | 12:00 PM
  #26
X2 on what he said. And no actually I don't be the hell out of it. It has seen 95% pavement and I still have these issues. Maybe its the road salt and potholes here.
Old Mar 24, 2009 | 12:03 PM
  #27
JK-Q8's Avatar
il try to look for the ball joints and check whats going on. if they are bad i hope the dealer will replace them cuz he didnt want to replace my steering since i have a bb. so all i got to do is jack up a wheels and move it around? and if it does then i have bad ball joints?
Old Mar 24, 2009 | 12:04 PM
  #28
Do what I said using a pry bar or shovel.
Old Mar 24, 2009 | 12:05 PM
  #29
jayrav's Avatar
If I didn't know any better I'd swear you live in Puerto Rico
I feel your pain
Old Mar 24, 2009 | 12:06 PM
  #30
JK-Q8's Avatar
so i just put the shovel under the wheel and move it up and down? and whats the bad movement i should see?
