Superchips flashpaq gas mileage savings spreadsheet!
#51
The stock 3.8 is no more of a pig than the I-6 motors, just a different rpm range. In fact the stock 3.8 has more hp and torque, you just need to pump about 30% more rpm into it which certainly isn't conducive to off road ventures.
As for performance gains from the Superchips, and with my tests I'm pulling an additional 15 hp based off of improved 0-60mph times, went from 9.84 seconds to 9.14 seconds. Yes, still a pig, but an improved pig where there isn't the option to change mechanicals as many have done with a better cylinder head, and fuel injection on the 4.2L.
The cost/value of the Flashpaq exceeds any performance upgrade for the JK that I am aware of. Certainly there is more power to be had with a RIPP SC Kit, but dollar per hp it's two totally different leagues. Also, squeezing more power out of the 4.2L didn't exactly come on the cheap either as a cylinder head replacement and fuel injection upgrade would lighten your wallet by a couple grand, albeit with better increases.
#52
Correct me if I am wrong, but the 4.2 hasn't been used since the mid 80's. The 4.0 came online late 80's with the High Output 4.0 in the 90's. I've had all three in past Jeeps. I agree that the 3.8 minivan moto they put in the JK is comparable to the 4.2 on highway performance but the 4.2 could pull a house down, the 3.8 would blow a gasket screaming over 5k rpm to just get close to the 4.2 in that regard. The 4.0 first edition or High Output is still my favoirte Jeep motor, even when I had a 350 dropped in one Jeep. It is ironic that EPA regs prevented the 4.0 motor use in the JK, b/c I got better mpg out of my old 4.0 Jeeps than I do my new 3.8 JK (granted JK Unlimited is much bigger with 4 Doors and cargo space).
My wife has a 3.5 (honda) motor in her 09 Pilot, which is basically a slightly smoothed out brick and weighs even more, she can't stand the accelration in the JK, the Pilot kicks the poop out of the JK AND gets much better mpg. I don't understand why the JK is sooooo inefficient, which is why my focus is on mpg improvements first, power second.
I still haven't heard any real information on which is better, hypertech econ max or superchips, for mpg. Comments?
#53
While I am not the guy to ask about which programmer works better as my rig was outside the bounds of what Hypertech could deliver, I had way better results with the Superchips in both performance and efficiency. Also, if you really wanted to throw some dollars at it, which might not be so wise, I'm sure you could get some pretty stellar results out of a Diablo Sport Tuner and aftermarket upgrades not supported by Superchips or Hypertech.
#54
The guys stuck running the overheating automatics (like me) feel more of a benefit from recalibrating for tire size because it corrects the shift points of the tranny. I noticed from your info that you're running 35's on 3.21 gears with a 6 speed. A programmer isn't going to overcome that math. Sell the programmer to someone with an auto, regear your axles, and use the cheaper AEV Procal to recalibrate your speedo for tire and gear change. I'm betting you don't even use 6th anymore unless you're on a long downhill on interstate. You need an axle ratio in the upper 4 (4.88?) or lower 5 range to get the gerbils back in their power band. With your current setup I doubt you'd even feel much difference if you programmed for premium fuel (and filled up with high-test) - there's only so much we can squeeze out of these little van motors and your gear ratios are definitely working against you.
#55
#56
This are the Feautures that the Superchip offeres-
TUNING
Industry leading Jeep tuning
91-Performance
87-Performance
Towing: Heavy Load Use
Mileage XS: Fuel Economy
CRAWL: High low-end torque off-road mode
All tunes work in 2WD, 4WD-HI & 4WD-LO
OFF ROAD FEATURES
Superchips exclusive CRAWL off-road tune
Tire size calibration of speedometer available on properly equipped Jeeps
Transfer case gear calibration on 2005 and newer Jeeps if properly equipped
Axle gear calibraton on 2005 and newer Jeeps if properly equipped
4WD-HI axle lock with auto-disengage safety feature
Tire Pressure Monitoring System threshold adjust
Real time idle control for running accessories
TRANSMISSION
Superchips Optimized transmission performance standard on all Jeeps
Wide Open Throttle shift points tuned on most Jeeps
Shift firmness optimized on all Jeeps
Advanced transmission tuning product available on newer Jeeps allowing for custom shift schedules, firmness and shift points
ADVANCED ENGINE PERFORMANCE
Rev limiter adjustable on 2005 and newer Jeeps
Speed limiter adjustable on all Jeeps
Throttle body relearn available on newer Jeeps
Spark advance settings available on older model Jeeps
Fan temperature on/off available on Jeeps with electronic fan control
Read & clear diagnostic trouble codes standard on all vehicles
NOTE: Features vary be year, make, model and engine. Search by vehicle in question to find out the details. All Superchips tuning products for gasoline-fuled vehicles are either covered under CARB Executive Order number or are in a pending state. All non-racing Superchips tuning products for diesel-fueled vehicles are on the CARB products in progress list pending CARB testing and approval.
TUNING
91-Performance
87-Performance
OFF ROAD FEATURES
TRANSMISSION
