Tf 2.5 bb
The rear swaybar links should be installed on the inside. The rear TB bracket helps recenter the rear axle, but wheel spacers still might be needed. I saw a 09 Rubi in Moab that had the 2.5" coil kit and stock rims/tires. Clearance didn't seem to be a issue after talking to the owner. It seems that not all the stock JK rims have the same backspacing.
there are 2 members in my club with this lift, one rubi and one x running rubi shoes. both of them put the swaybar endlinks on the inside, and both have no problems, just be concerned while running the links on the inside, the clearance with the links and the brake lines. neither of them had the issue, But I (running the links on the outside) had an issue with the metal portion of the brake line and the endlink bolt. quick fix, just bend the line closer to the frame.
Also, me and one of the guys in my club did not use the trackbar relo bracket and still have no probs.
I say go for the lift and be happy.
So....just so I have this right....are you saying Teraflex now says wheel spacers are NOT necessary on the kits with the rear track bar relocation bracket? I'd like to hear what Joe says about this. That sure would be nice, because I'd really like to stick with my stock wheels.
So, that's how my situation played out. I put on spacers=no rubbing, TF said relocation bracket = no rubbing for factory wheels, bigger wheels= wheel spacers, bigger wheels= rubbing with relocation bracket. If I did it again I would do it the same.
I ran the TF BB for one day, WITH the track bar relocation bracket, with the stock Rubi wheels, no spacers. The swaybar links were so close to the wheel inside edge that any bump would cause them to contact the wheel edge. I got spacers then, and did not drive it until I put them on. The same result could be achieved by flipping the swaybar links to the inside of the brackets as stated above, but I chose spacers 'cause I wanted my wheels and tires further out. It looks better that way IMO.
BTW, with the trackbar relocation bracket, stock wheels and no spacers, the swaybar links would contact on both sides, so the axle was centered.
Or do you mean they will be equal again. thx.
Meet me at Quizno's and I'll buy just so there are no hard feelings
I ended up flipping the links on the driver side and its still only 1/2 an inch away from the tire sidewall.
I have stock 09 steelies. at any rate I ordered the Relo brackets front and rear.
Also It was funny to see the front shocks had totally failed by 3000 kilometers. I compressed them and they stayed compressed.
Junk.
Glad I immediatly went to bilstiens.
Junk.
One post above stated that they had contact on one side. I was just pointing out that the swaybar links were close to both rear wheel rims equally, since the axle was now centered again.
The reason the swaybar links don't contact the wheels without a lift is because the swaybar link upper end is below the height of the wheel rim, therefore it does not come near to contacting the rim. When you raise the suspension, the swaybar link end is now about the same height as the top of the wheel rim, at least on a BB with their longer swaybar links anyway.
