Transfer case just exploded!!!
Old May 18, 2011 | 07:27 AM
  #41
tattedfire's Avatar
No, don't have any tcase pics. Need to get some though. Unfortunately I'm at work for 24hrs so won't be able to get pics today. Maybe tomorrow. The case didn't crack at a seam like where the two halves meet up. It actually cracked perpendicular to the seam. More where the rear output shaft is. From what I could see the front appeared fine
Old May 18, 2011 | 08:41 AM
  #42
wayoflife's Avatar
JK-Forum Founder
Originally Posted by tattedfire
So you recommend getting another stock TC and using the stock DS if it is still good (I'd get it rebalanced of course)? Do you still recommend upper adjustable CA's? If so which brand? I just don't want this happening again. Pretty sure I'm gonna go with 4.56 gear instead of 5.13. I didn't like my jeep turning 3000 rpms going highway speed.
actually, if the chain and planetary gears inside the t-case are fine, you should be able to reuse them and just replace the broken case. if just the rear half is broken, i think it's only $300-$400 for it. regarding the drive shaft, yeah, if it's still good, why replace it. no need for adjustable rear uppers if you are not getting a new u-joint style replacement shaft. as far as gears go, i personally would recommend 4.88 - it's a good fit for 35's.
this is what most of the broken t-cases look like.
Old May 19, 2011 | 09:06 PM
  #43
backroadman81's Avatar
Originally Posted by backroadman81
I don't think a drive shaft would do what the OP is telling us. I would look more at the transfer case havin a problem. Something would have to stop turning either in the rear or in the transfer case to cause a problem like that.
To the OP did you feel any vibration before everything let go? If it was the drive shaft letting lose you would have felt it going.
I hate to say it but... I TOLD YOU SO!!
I have seen a similar problem like that in a 1/4 mile drag car. In that case a ring bolt came loose got in between ring and pinion and broke like yours did. Luckly it broke about the 60ft mark and not further down the track. Close to the same thing happened to the transmission that happened to your transfer case the shock of it stopping blew his tail shaft apart.
As for the gearing I would look at 4:88. Just personal prefence.
Would like to see a video of the cover being takin off the rear and of the damage to transfer case. If you could manage that. little easier to get a internet diagnosis like that.
Old May 20, 2011 | 04:12 AM
  #44
muttsjk's Avatar
Man that sucks , hard to tell what caused it , as others have stated , but one possibility that has not been stated is a bad pinion gear , maybe bad metal and it snapped , causing the other damage , what brand were gears ? did scott install for you or someone else , he did my and I've had no issues , I did just install ca's in rear and new driveshaft just for piece of mind , pm me if you deside to replace driveshaft with cv shaft I found a place online that has really good prices
Old May 20, 2011 | 04:25 AM
  #45
Ryanc's Avatar
Any input from the gear, driveshaft installers?
Old May 21, 2011 | 01:17 PM
  #46
tattedfire's Avatar
No input from installer. He's actually out of town till Monday. I was aware of this as he told me he was leaving Wednesday night before I left with my jeep. The gears were Yukon. I'll try my best to get a video and pics of the rear diff
Old May 24, 2011 | 09:43 AM
  #47
tattedfire's Avatar
The ARB is scared up pretty good but the internals seem fine. The installer has a brand new atlas 2 he's selling for $1800. So debating on whether to put that in or not.
ID:	164057   Click image for larger version
ID:	164059   Click image for larger version
ID:	164060   Click image for larger version
ID:	164065   Click image for larger version
Old May 24, 2011 | 09:54 AM
  #48
The_Yeti's Avatar
go with the atlas! lol if he is doing all the labor no charge that would be a good deal
Old May 24, 2011 | 10:22 AM
  #49
mkjeep's Avatar
I wouldn't pay him shit, wouldn't trust the atlas he's trying to push either. I'd tell him to fix everything back like it was, he did a gear install, you left the place and blew your shit to pieces. That's a helluva blown tcase.musta Pinion looks like it did a number on the locker casing.
Old May 24, 2011 | 10:32 AM
  #50
Mad-Hatter's Avatar
x2, I agree
