Trashed 5.13's
When you get into the higher numerical gear ratios on the Dana 30, the pinion does get a bit smallish, so it would not be outside the realm of possibility that you grenaded your front gears due to the stress... but from what I read on the board, there are myriad guys running 35s on regeard Dana 30s and they seem to get away with it more than they don't.
<shrug>
<shrug>
Here is the picture of my ring gear from the front diff.
Ben
http://my.project-jk.com/showphoto.php?photo=48524
Ben
So is it not wise to run 5.38's in a Dana 44? Was advised to go that way.... but with your post I may want to reconsider.
Currently running 37's w/ the 4:10's and was looking to regear. Told 5:38's was the way to go for the current setup.... and figured it will work for future 40's?
Ben
Ben
Ben
Ben
I have 5.13's ready to go on, and I also have 35's and a Dana 30. Was also under the impression that 5.13 was optimal for 35's and an auto, to get back some performance (I remember seeing some charts some where) and to give the stock tranny a break but....
No? This configuration is a recipe for failure?
Hmmm..... just learning as I go along
so if the 30 was upgraded to a 44 it would less likely to explode with 5.13?
so if the 30 was upgraded to a 44 it would less likely to explode with 5.13?if you've got the gears, go with them but just be mindful of them.
OP... David will need to see the best photos you can get with no glare of the wear pattern on the unhurt teeth and a close-up of the damaged area, of both the ring and pinion gears. What he'll be looking for is the wear marks being in the correct position on the teeth.
If incorrectly setup the wear mark (contact marks) will be deeper than usual because you had the whole force on a smaller area and of course in the wrong place.
The other choices are defective gears or you played to hard, of which you cannot distinguish from the naked eye. Only YOU know that.
