Upgrading my wheels, info please
Old May 25, 2015 | 08:34 AM
openx's Avatar
Question Upgrading my wheels, info please
Hey there folks, I have a stock 2011 Jeep wrangler. I am wanting to change wheels to something cooler, my question is what size wheels work with a stock setup? Info, advice, and anything else would be great thx!
Cheers
Old May 25, 2015 | 08:40 AM
Invest2m4's Avatar
95% of people go with 17" (most are 8.5"-9" wide). You could go 18" or even 20", it just gets more expensive and provides less options (and you'll take some crap for rolling 20s).
You can squeeze a few 15" wheels on, but in my view, there are too many drawbacks. People do it because the wheels and tires are cheaper in a 15" wheel.
The other thing to keep an eye on as you narrow wheels down is the back space. Basically, it measures how far the wheel will stick out. If you plan to run larger tires, you want less back space, which will provide additional tire clearance. Stock is something like 6.25" or 6.5". Most common wheel upgrade is to a 4.5" back space. That works great for up to 35" tires. If you plan to go 37", 3.5" is best.
Old May 25, 2015 | 09:32 AM
openx's Avatar
Thank you so much, here is a couple I have been thinking about, just to get some input. this is my jeep {basically} I like the Black wheels but think they would blend in to all the other black of the Jeep.
Classic III Polished Alloy Wheel
Technical Details
• Fits 2007 to 2015 JK Wrangler, Rubicon and Unlimited
• 2 and 4-door models
• Fits 1999 to 2015 Grand Cherokee
• Wheel Size: 17x9
• Bolt Pattern: 5 on 5
• Backspace: 4.5
• Max Load: 2500
• Offset: -12
• Finish: Polished
Sidebiter II, 17x9 with 5 on 5 Bolt Pattern - Satin Black
Technical Details
2 and 4-door models
Wheel Size: 17x9
Backspace: 4.5
Max Load: 2600
Offset: 0
Finish: Satin Black
Dick Cepek
GUN METAL 7, 17x9 with 5 on 5 Bolt Pattern - Gun metal gray metallic
Technical Details
2 and 4-door models
Wheel Size: 17x9
Backspace: 4.5
Max Load: 2500
Offset: -13
Finish: Gun metal gray metallic
Old May 25, 2015 | 10:17 AM
Invest2m4's Avatar
Those all work. I agree about the black on black. Gun metal or a brushed alloy would look good. Not a fan of polished as it looks like chrome.
Old May 25, 2015 | 10:22 AM
Invest2m4's Avatar
This won't help much, but here are a couple pics of wheels I've had. First were machined aluminum and the second were a black center and machined aluminum bead lock ring.
Old May 25, 2015 | 11:08 AM
Baddkarmaracing's Avatar
what size tire is that and how much lift?
Old May 25, 2015 | 11:24 AM
Invest2m4's Avatar
37" MTRs and exactly 2.5" of lift using the factory measurement method. The MetalCloak Overline fenders up front sit about 2" higher than a standard flat fender. Gives the illusion of more lift (the function is 2" more uptravel).
Bad picture, but here it is with 40s and 4" of lift. Only reason for the additional lift is that I'm running 16" travel ORIs and to get 6"-7" up, I needed that much lift. My axle almost hits the frame at compression.
Old May 25, 2015 | 12:07 PM
I think I am going to have to look into those fenders and that is the tire I was planning on next I like that set up a lot. I have 35's and an RK lift and stock bumps, my tires barely touch the shittybilt fenders and the shock is within 1/2" to bottomed out so maybe those fender I will would ok with stock bump or maybe 1" added bump at the most.
Old May 25, 2015 | 12:29 PM
Invest2m4's Avatar
I ran the 6pak shocks and 2" bumps front and rear. Was perfect. Sorry to the OP for the derail.
Old May 25, 2015 | 01:07 PM
OP this is what I run on pretty much the same jeep as yours it's the eagle alloy series140 polished, these haven't been polished in idk how long though lol
