Weird Steering Issue
Sent from the fast lane while driving one handed.
For your track bar, did you lift it? With a bracket? I have an adjustable track bar but I'm going to put back on my OEM track bar with a relocation bracket.
The kit comes with a longer unit, but is not used as the flip kit takes care of the added length by moving things up higher.
You need at a minimum 3" of lift. From reading and experience with other solid axle jeeps, 3.5"+ seems to be when you would want to flip it and raise drag link to be parallel with trackbar.
Sent from some string and a few tin cans.
Well, I put in 4" coils so I think I'm gonna put in the flipped drag link, track bar relocation bracket, then fit the OEM track bar and measure, if I need more, I'll put in the adjustable track bar.
Well, drag link flip cured some of the problem but control arm relocation brackets fixed it completely. My caster is around 6 now and everything appears to be good now.
