Weird Steering Issue
Old Jun 25, 2013 | 05:32 AM
  #21
Collyn's Avatar
Originally Posted by SpudNuts
I don't feel it binding on anything. I'm going to go with flipping the drag link but i'm not sure if its safe to do it with the OEM drag link or do I have go get a new one.
It is safe to use the stock drag link. It's just not as sting as an aftermarket. Same benefit to steering though. Only reason I replaced mine was my TREs were worn on both ends.
Sent from the fast lane while driving one handed.
Old Jun 25, 2013 | 02:55 PM
  #22
SpudNuts's Avatar
Well, I ordered the Poly Performance high steer drag link. Might as well do it right.
Old Jun 25, 2013 | 05:54 PM
  #23
SpudNuts's Avatar
Originally Posted by CerOf
I have the AEV flip and you use an OEM drag link. Also uses the stock trackbar for 3.5" of lift. If you are taller, you may need adjustable trackbar.
Sent from some string and a few tin cans.
For your track bar, did you lift it? With a bracket? I have an adjustable track bar but I'm going to put back on my OEM track bar with a relocation bracket.
Old Jun 25, 2013 | 08:28 PM
  #24
CerOf's Avatar
The AEV SC with flip kit came with a bracket on axle side to raise it. You retain a stock track bar. Mine is stock track bar; otherwise, you'd need a much longer/adjustable.
The kit comes with a longer unit, but is not used as the flip kit takes care of the added length by moving things up higher.
You need at a minimum 3" of lift. From reading and experience with other solid axle jeeps, 3.5"+ seems to be when you would want to flip it and raise drag link to be parallel with trackbar.
Old Jun 26, 2013 | 01:52 PM
  #25
SpudNuts's Avatar
Well, I put in 4" coils so I think I'm gonna put in the flipped drag link, track bar relocation bracket, then fit the OEM track bar and measure, if I need more, I'll put in the adjustable track bar.
Old Jul 4, 2013 | 06:20 AM
  #26
SpudNuts's Avatar
Well, drag link flip cured some of the problem but control arm relocation brackets fixed it completely. My caster is around 6 now and everything appears to be good now.
