What is the best rattle can bed liner to use?
Old Aug 8, 2010 | 12:13 AM
OFCRyan's Avatar
Default What is the best rattle can bed liner to use?
I have a few things to bed line and I'm not sure what is the best bed liner to use. Also if u know where to get it from that would be awesome too! Thanks
Old Aug 8, 2010 | 01:58 AM
TN-MEDIC-14's Avatar
From: Christiana, Tennessee, United States, United States
I have used dupli-color spray on bed liner on my wheels , grill and rock rails and it has held up great so far, I get it at advance auto for $8.99 a can.
Old Aug 8, 2010 | 02:05 AM
zook's Avatar
I used Duplicolor also and it worked well. Sprayed my front bumper with it. I would use it again.
Old Aug 8, 2010 | 05:37 AM
Ario56's Avatar
+1 for the duplicolor. i used it on my fair lead, and subwoofer enclosure. i've seen it at almost every parts store and most places with an automotive department (sears, walmart, target, etc...)
Old Aug 8, 2010 | 07:04 AM
mack78's Avatar
Default Line-X
I had my 85 CJ7 Line-X'ed inside and out, but not underneath. Also had my tube front bumper done. And with a limited life time warranty, it's an investment. My whole Jeep cost me $1K and I am planning on getting my new '11 Rubi done after a few years.
ID:	80685   Click image for larger version
Old Aug 8, 2010 | 09:48 AM
nthinuf's Avatar
Another vote for Duplicolor.
Did the inside of my freedom top, wheel wells after chopping the flares, touch-ups on the front bumper, etc. I'll do the outside of the top with it when I get a bit more un-lazy...
https://www.jk-forum.com/forums/show...ruck-bed-liner
Old Aug 8, 2010 | 09:56 AM
SilverJK12's Avatar
Originally Posted by DethKlok
I like the Rustoleum, but regardless of what you use, DO NOT TOUCH at all until completely dried.
I agree. It takes awhile to harden. 3 hours at least. I did my fender wells and is perfect!!!!!
Old Aug 8, 2010 | 09:59 AM
SilverJK12's Avatar
Ace or o reillly has many choices and usually 6 cabs in stock in case you want to bed line everything !
Old Aug 8, 2010 | 11:53 AM
JK-Rubi's Avatar
I've only used Duplicolor, but I believe one of the greatest contributors to a decent application of bedliner is the used of a "pistol grip" handle. I've tried spraying without the grip and it was very hard to control the amount of spray. With the grip - it was a breeze. Bought mine at Walmart for like $3. It also allowed me to spray the surface directly without having to use the overspray approach (when the Duplicolor begins to run out, it does start blotching).
Below is a pic of the grip I mention above attached to a can of Dupli-color.
Old Aug 8, 2010 | 03:35 PM
Widowmaker's Avatar
I just used Rustoleum bedliner this weekend to do my grill. I am impressed, it has even texture and a very close color match to stock bumper and finders. It dries fast...I was second coating within 15 minutes of first coat.
