what's wrong here??!!
Old Jan 20, 2011 | 12:20 PM
maroon jk's Avatar
Default what's wrong here??!!
need help to figure out what is this and what's leaking from here??? and what i can do to fix it?Click image for larger version
ID:	119709Click image for larger version
ID:	119710Click image for larger version
ID:	119711Click image for larger version
Old Jan 20, 2011 | 12:28 PM
4WHLN's Avatar
Kinda hard to tell from the pictures, but it almost looks as if your front main pulley seal is leaking and dripping down on to your oil pan. Can you get more pics from around the pulley?
Old Jan 20, 2011 | 12:43 PM
maroon jk's Avatar
yes i can. what is the pulley so i can take pics around it??
Old Jan 20, 2011 | 12:44 PM
angermgmt's Avatar
what color is the fluid?
Old Jan 20, 2011 | 12:46 PM
CTNEDGE's Avatar
I agree with the first responder. The pulley is the round thing at the bottom of the motor in front of your pan. Looks shiny like antifreeze as well so could be water pump. If that's the case you will see the shiny above that pulley.
Old Jan 20, 2011 | 12:47 PM
maroon jk's Avatar
its brown, like the color of oil.
vandegrift's Avatar
Looks like it might be a warranty issue, I'de take it to the Stealership, and get them to look at it. Probably fix under warranty. Good Luck
Old Jan 20, 2011 | 12:49 PM
angermgmt's Avatar
Possibly the front seal. Double check the filter....
maroon jk's Avatar
is it the yellow thing in the pic??
Old Jan 20, 2011 | 12:53 PM
angermgmt's Avatar
what does the fluid smell like?
