Will I regret 37s?
I'm going to be getting the RK 3.5in 8 arm lift. I'm torn between 35 and 37in tires. The fine people from RK are telling me to go for the 37s. I know I will someday want them(that is why Im doing the 3.5 in lift) just not sure if i should start with the 35s. Im in a 09 rubi 2dr 6spd. I'm keeping the 4.10 gears for now either way. Im ok if its a little sluggish.
Any thoughts?
Any thoughts?
Go with the 37's and don't look back. I thought I would never go bigger then 35's
what was I thinking....
I got a 3.5 RK lift and wish I had 38's. The only reason I stayed with 35's is because I went with 15" rims back when I first started tis project...Live and learn I gues...
Alloy those axles and your good to go,,,,
Good info, thanks, did I mention this is my DD? I may have left that out. But my commute is only 30 miles round trip. When you say alloy the axles that is referring to sleeves right?
I've seen a lot of people make this mistake and it cost them more money in the end. Whether it's lift height, tire size or wheel size, go with the bigger of your choices. If you are even considering 37's, that is what you need to go with. If you settle for 35's, you will be regretting it in short order and trying to sell your 35's so you can buy 37's.
