Will I regret 37s?
I'm going to be getting the RK 3.5in 8 arm lift. I'm torn between 35 and 37in tires. The fine people from RK are telling me to go for the 37s. I know I will someday want them(that is why Im doing the 3.5 in lift) just not sure if i should start with the 35s. Im in a 09 rubi 2dr 6spd. I'm keeping the 4.10 gears for now either way. Im ok if its a little sluggish.
Any thoughts?
Any thoughts?
I just did a 3.5 clayton lift with 37's and Im luvin every minute of it. It is also my DD. I also did everything else like gears, gussets, high steer kit, etc... I dont regret it one bit. You will love it.
I have an X and I went from 33's to 37's this past January. I was debating between 35's and 37's but because I have the 4 door I went with 37's and I wouldn't regret or waste money on smaller tires when I have always wanted 37's. All I have done to my D30 is the evo C gussets and LCA skids. The rest of the axle is stock. I even am running the stock 3.73 gears. From all who I have talked to who have been running 37's on their 30 they recommend keeping the front open to not stress the axle too much. I also run stock shafts and carry a set of stock shafts in case I break one. Get the 37's.
What is your gas mileage like?
