Going with 35's - Heard I need C Gussets??
I have a 2012 auto with 3.73 gears. I am planning to go with 35" tires on a 2.5 AEV lift.
I heard that I need C Gussets if I do this.
Can anyone tell me if this is true and why?
FYI- I don't plan to wheel this thing a ton. Perhaps 2-3 times a year.
Thanks!
Thanks!
It is true. The end forgings on the JK front axles or, "C's" are really weak and will bend with anything other than stock wheels/tires. Running 35's even around town will eventually cause the C's to bend and that will give you camber that cannot be corrected or, at least, very easily. C gussetts will help prevent this from happening.
Ouch - great...I guess it's true when they say Just Empty Every Pocket.
Who makes some decent ones? I'm not sure if I can mention the online site I'll call "Q", but I can't seem to find any on their site. Any suggestions would be appreciated.
https://www.jk-forum.com/forums/faq...._faq#faq_rules
i personally like and run off road evolution c-gussets
EVO: Gussets/Brackets, EVO Mfg C2 Axle Gussets
i assume you are referring to quadratec and, before you make any other assumptions as to what you can and can't say, i would recommend taht you simply read the rules of the forum.
Originally Posted by Bunk
Thank you. Looks like I only have to do the front axle as the rears are different.
