Alpha Expedition: Gobi Roof Rack.
Old Jun 1, 2012 | 09:09 AM
  #761
07Rubi's Avatar
Originally Posted by AU Bronc N JK
Yup! I LOVE the gobi racks.. they are TOP NOTCH! However, they do make your vehicle suffer on the fuel economy.. especially when coupled with 35's, 4.56's and a 3 in lift. But, in my opinion it's totally worth it.. and you make up the fuel costs by sleeping in the tent and not spending money on hotels!
You could improve the mileage... but it would take a HEMI and a LIGHT FOOT to accomplish that... I'll be doing the HEMI in the coming year or two for sure.. pentastar is nice, but it's no HEMI! haha
Luke
What are the final numbers on a Hemi Swap out the door, if you have a shop do it for you? Kit from AEV right? Crate Motor? Labor? Let's say the 5.7...
Also - I keep waiting for a good diesel option!
Old Jun 2, 2012 | 01:20 AM
  #762
AU Bronc N JK's Avatar
I'm looking at putting the 6.4L HEMI crate engine in my jeep. Just for the crate engine alone, (with wiring harness, cpu, and efi) is $18,485. You will also need a new transmission that can handle the crate engine (another $6,000), and an adapter for either the rubicon tc or an atlas. All said and done, out the door with everything installed (by a shop) you'll look bw $25-30K finished. If you do it yourself you can save a couple grand easy. Again, this is with ALL NEW components!
Luke
Old Jun 2, 2012 | 03:20 AM
  #763
JKingAround's Avatar
Just find your self a wreaked ram with low miles I found one with 18000 miles for 2 grand a rebuilt tranny for another 2400.
Old Jun 2, 2012 | 01:58 PM
  #764
07Rubi's Avatar
Luke
That is a serious commitment. Wow. I think about about to drop $20K on axles, lift and suspension though so what can I say? If I had the Pentastar, I probably wouldn't care half as much.
A great way to save money, but I've got too much OCD. I'd be worried about the wrecked motor having hidden problems. All of that being said, it seems like a diesel swap might actually be cheaper and that's for better torque, less tech in the engine and a motor that will run forever with minimal maintenance. Oh and will also run on bio-diesel or WVO.
Old Jun 4, 2012 | 09:37 AM
  #765
Cool Danish's Avatar
https://www.jk-forum.com/forums/memb...ack-jku-10221/
I HAVE had an issue with this that I'm still sorting out. The AirTop Black Storm Medium, which is what I have, does not have a long enough track to be mounted to both sets of the Gobi cross bars that would be flush with the bottom of the tent. I could solve this by moving the tent back some so it's a$$ hangs off the back a little, but I have two camping work lights back there so that is not an option. As a result (and you can see this in my install picts), there is a lot of distance between the rear cross bar I had to use and the bottom of the tent. This space allows it to wiggle a bit and although I've driven it several thousand miles with no issues, if I do a super technical trail with step descents in the area of 30 degrees or so and I have to hit the brakes hard, the tent slides forward and the rear mounting points slide out of the track. It is still perfectly secured believe it or not, even at highway speeds with just the front two, which are closer to the middle than the front, but it's obviously disconcerting. I'm working on a solution.
Additionally, I've had no luck with the Gobi wind deflector in almost any situation. Prior to the Maggiolina, the soft top flapped like crazy in the back. After the Maggiolina, that went away, but there is significant white noise wind noise up front now. I've been told the tents are pretty quiet so then I removed the wind deflector and it made almost no difference. The problem could possibly be exacerbated by the 4 IPF's I have up there as well, but I'm still looking for a good wind noise solution.
Scott
Hi Scott,
Thanks for install comments and pictures. Looks like mounting the AirTop Black Storm to the Gobi rack is not as plug and play as I first thought.. :-( How do you like the medium size of the AirTop Black Storm? Is it large enough for 2 people or would you recoment the large size? (6 inches wider).
Have you thought about modifying the Axe/shovel mounts, instead of raising the RRT on the Gobi rack? Lower profile should be better for both off camber situations and less wind resistance.
- Michael
Old Jun 7, 2012 | 10:59 AM
  #766
SIDsjeep's Avatar
Veteran: Coast Guard
Default help
wahoo i made the leap and ordered my gobi 2 weeks ago now im just trying to get the prep work done the 2 bolts in the back on each side where the rack mounts up busted when i originally took off my stock bumper so this is now coming back to bite me in the ass. anyone have any good tricks on busted bolt removal? i've tried drilling but im going threw bits like cigarettes and im not sure if the rack requires the use of the same bolts and if they actually thread into the frame. id appreciate any help with this thank you. if some one could send me a pm with some advise id appreciate it thank you
Old Jun 13, 2012 | 09:39 PM
  #767
07Rubi's Avatar
Originally Posted by Cool Danish
Hi Scott,
- Michael
Hey Michael,
Sorry so long to respond. The tent seems great so far, but I've yet to actually spend a full night in it. Hoping to do that in about a month. Been doing some other build out stuff. The medium seems like it's going to be fine for two adults and a kid (I have a 3 year old), but I just won't be sure until I try it. If I remember correctly, the black storm was not available in large when I ordered, but I probably would have stayed with the medium anyway because I didn't want to have the sombrero effect. I've been able to build my JK up without doing anything super goofy looking yet, and I didn't want to start with a super wide tent.
As for modifying the mounts, I'm not really sure how I could. Some kind of flange needs to go over the tubing, unless I weld something on. I'll also be dealing with the ARB awning mounts as well, which work the same way. I'm having an interior build done now with an ARB fridge and drawers and storage by American Offroad Expedition . They are looking at solutions for me with the tent. I'll keep you posted.
Old Jun 18, 2012 | 05:14 AM
  #768
Revelstoker's Avatar
Quick question; can I run a 2011 Gobi Stealth rack on a 2007 JKU? Reason I ask, is that when I replace the '07 for a new model I'd like to take the rack with me! Thanks,
Old Jun 18, 2012 | 10:38 AM
  #769
fm3fm3's Avatar
How long has it been taking for most of you to get your rack? I ordered mine in May 5th and still no word on it even being shipped yet.
Old Jun 18, 2012 | 11:57 AM
  #770
Carpe Diem's Avatar
A friend and I put our racks on the same order back on May 10th. The order was marked shipped a month later (Jun 11), though they haven't arrived yet.
