New! Soon to be Released 2012-Up JK Bolt-on Air System
Also, since you're not doing a wiring harness for this, can you make some recomendations on what we'll need to get, like length and gauge of wire necessary for this? I'd like to get this stuff on hand before the unit shows up. Thanks!
I will create a wiring diagram and post for everyone.
Yes, absolutely. In the wiring diagram, there will be these recommendations. Typically 10ga. wire will work, but I always lean on the side of overkill, so 8ga. is good. For the power switch to trigger the system on via the relay, 12ga. will be fine, since very little load is on this wire.
