Poison Spyder Hood Louvers--Now for JK!
Old Jun 18, 2012 | 07:39 AM
  #151
maldoro's Avatar
For those of you that installed...How the powder coating? Was thinking about purchasing the bare metal and prime and painting myself.
Old Jun 18, 2012 | 07:43 AM
  #152
myklt8's Avatar
Just ordered mine!
Old Jun 18, 2012 | 07:51 AM
  #153
afpilot82's Avatar
JK-Forum Ambassador
I ordered mine already powder coated for ease of install. The finish is solid, time will tell how it holds up.
Old Jun 18, 2012 | 07:54 AM
  #154
Dblaron's Avatar
I got the bare metal and got a textures flat black powder coat. Only cost $35 to do it. Very easy install and looks great. The tramp stamp increases the cabin pressure when windows up and ac running but pulling some of the drain plugs in floor fixes the problem.
ID:	330738   Click image for larger version
ID:	330739   Click image for larger version
ID:	330740   Click image for larger version
Old Jun 18, 2012 | 08:00 AM
  #155
SpyderSales's Avatar
Sponsoring Manufacturer
Poison Spyder Representative
Thanks for sharing your pics! It looks sweet!
Timmay
Old Jun 18, 2012 | 12:40 PM
  #156
mOjO_JK's Avatar
Should be getting it tomorrow! ..what size hole saw do I need?...and can I just use touch up paint after I make the cuts or did u guys prime the cuts first then color matched it?
Old Jun 18, 2012 | 07:37 PM
  #157
Dblaron's Avatar
Your really don't need a hole saw. Its i just scored the paint with razor blade along the stencil so i could see where they wanted the cuts and used a cut off wheel to complete the lines. You will need a small hole saw or step bit for the bolts that are thru the brace area. Just male sure when you cut on cut thru the outer skin. I used plastidip on all the bare metal edges to prevent rusting. Easiest if you pull hood off for sure.
Old Jun 19, 2012 | 02:54 AM
  #158
OH9JK's Avatar
JK-Forum Ambassador
Good weekend project! Follow the instructions and remember to take your time measure twice and cut once. The template makes this easy!!
Here are some pics...Jeep still a bit wet from the morning dew
ID:	331109Click image for larger version
ID:	331110Click image for larger version
ID:	331111Click image for larger version
ID:	331112Click image for larger version
Old Jun 19, 2012 | 06:18 AM
  #159
maldoro's Avatar
perfect...this is the route I'm going to go. Just ordered the bare metal. Thanks for sharing.
Old Jun 21, 2012 | 03:28 AM
  #160
dpowell5523's Avatar
I wonder if I could order this without the holes for the bumpers. I don't plan on folding the windshield down......ever.
