What would you like in a snorkel design?
Old Mar 15, 2011 | 04:21 AM
  #691
Rugged_Ridge's Avatar
Former Vendor
Originally Posted by Tuto
1 -The plastic degrades with time even if UV protected. That is why a mentioned other material. With plastic you have to gave a mold($$) made and use injection machines to make them (If that is how you plan to manufacture them)
Using a metal alloy, that will not rust, you can lower your production cost. It will not brake like plastic and you can Paint it any color you like.
2- The Triangule shape was just food for though.
(1) Plastic is used for the complex shapes that will be required. Up front tooling cost will be higher but overall pcs cost is much lower.... The more you sell the quicker you can pay off your tooling cost. Fabricated units will always have build cost that can only go up over time. As for plastics...? Have you looked at your JK? wonder if your fender flares will last the life of your Jeep if you don't replace them. It all comes down to the quality of the materials used.
(2) The shapes, as noted, will change. The images shown, also noted before, are development mules. We will do working on getting them cleaned up. As for the triangular shape it really would not do much. You still have a 3 1/2' tall wall (W/S) that you are mounting it to.
If air flow is a concern I would stay with the low mount. it sits lower and in a low pressure area. (No real wind affect).
Old Mar 15, 2011 | 04:22 AM
  #692
Former Vendor
Originally Posted by mkd1993
Think you can mount windshield lights with that snorkel?
Low mount.... yes
Old Mar 15, 2011 | 04:26 AM
  #693
Former Vendor
Originally Posted by racin444
Im hoping that low profile one is a little prettier when production comes out. If that ugly scoop wasnt on it and instead making the part it attaches to the scoop, it would look a lot cleaner.
This is a modular design. It requires a mounting base that can have a cover to direct air (low mount) and a sealing surface for the pre-filter or high mount. Making the base the scoop would complicate the attachment of the other intakes... So you see by making them separate we are cleaning up the design for all the intakes.
Old Mar 15, 2011 | 05:52 PM
  #694
emoody007's Avatar
Has any of your testing included Air Flow? i know it should get cooler air because its outside the hood but what about Air Flow Volume? Better, Worse or indifferent?
Old Mar 16, 2011 | 05:58 AM
  #695
Former Vendor
Until we run true Dyno numbers with the final product I'm going to go with indifferent. We made sure that no pathway was smaller than the OE air box opening. We do have a bit more pluming but at this time cannot detect any seat of the pants or timed drag differences.
Old Mar 16, 2011 | 10:42 AM
  #696
HotFrosty's Avatar
All I can do is hope that all goes so smoothly that it comes out early summer instead of late summer. Thanks again for your hard work.
Old Mar 17, 2011 | 05:50 AM
  #697
nikbass's Avatar
I wouldn't hold my breath projects usually go long, almost never ahead of schedule.
Old Mar 17, 2011 | 06:37 AM
  #698
Jethro0417's Avatar
Yea, while that may be completely true that doesn't mean we can't dream about it happening. Lol
Old Mar 21, 2011 | 08:32 AM
  #699
nikbass's Avatar
Dream brother dream... if it works for you I'll be right in line with you.
Old Mar 21, 2011 | 10:36 AM
  #700
wranglerdave's Avatar
THIS! Awesome, looks fantastic.
Originally Posted by Saharaunlmtd
Attachment 134897
I've been waiting soooooo long for this.
AEV = $370
ARB = $450
Please keep the short stack in the low end of this range and make my day.
