'09 Hood Latches...
Old Mar 29, 2009 | 02:58 PM
AZ Outlaws's Avatar
Default '09 Hood Latches...
... don't work!!
They are really no better than the old latches they replace. At normal highway speeds (65~80) they work fine. Throw in some head wind or pass a big rig going the other way on a two lane highway and the hood stills dances just as bad as it did with the pre-recall latches.
For now I went back to the zip tie fix. Next step seems to be the Daystar latch route. Do they actually work and put a stop to the hood flutter?
Thanks for your inputs.
Old Mar 29, 2009 | 03:19 PM
S4M14M's Avatar
Howabout a picture to compare, for the '07 + '08 owners......
Old Mar 29, 2009 | 03:46 PM
Suffolk JK's Avatar
With head winds and trucks on the highway doing 75 they seem to hold the hood down quite fine on mine...
Old Mar 29, 2009 | 04:11 PM
09SUNBURSTJK's Avatar
I had the same thing happen with my 09 the other day. We were on the highway at about 75 mph, as I got close to the back of an 18 wheeler the hood started bouncing up and down. Scared the @#&@ out of me, definitely gotta look into fixing it.
Old Mar 29, 2009 | 05:54 PM
AZ Outlaws's Avatar
No pics needed, the '09 latches look the same, only a little stiffer at first. Seems like after a month or two, they start stretching and are no better than the previous ones.
So, back to the original question... how do the Daystar latches seem to work over time? I understand they are much stiffer than the Mopar OEM ones.
Old Mar 29, 2009 | 06:15 PM
pearl-drum-man's Avatar
From what I hear the Daystar latches work well, I just took off my hood spring and have not had an issue since. It's free and takes about 30 seconds to accomplish.
Old Mar 29, 2009 | 06:26 PM
racer83l's Avatar
x2 on removing the spring. it doesnt do a thing for the JK and its a perfect free fix
Old Mar 29, 2009 | 06:54 PM
Atl JK's Avatar
Mine totally solved my problems. Night and day difference. $7, 5 min, and I still have the spring.
Old Mar 31, 2009 | 02:05 PM
AZ Outlaws's Avatar
Yeah, mine worked fine for almost two months. I guess the warm weather we've already had down here must of stretched them because the hood was jumping all over they place on the two lane highway a few days ago.
Old Mar 31, 2009 | 02:11 PM
saltman's Avatar
Mine never worked on my 2009. I could not tell a difference in the recall ones and the ones it came with. Jumps all the time.
