Aircon(and heat) wasn't working this morning
Old 06-18-2020, 08:05 AM
BrettB's Avatar
Default Aircon(and heat) wasn't working this morning
Aircon(and heat) wasn't working this morning. I ran a quick errand and it never came one. I turned the car on again, no luck, and then I accelerated up a hill and it suddenly worked. Any idea what might be going on?
Old 06-18-2020, 08:45 AM
resharp001's Avatar
Received 1,851 Likes on 1,620 Posts
Since you are referencing both the ac and heat, are you just talking about the blower? You're not saying the air is blowing but is neither cold when on ca or hot when on heat.
Old 06-18-2020, 08:51 AM
BrettB's Avatar
Not sure. There was no air coming out of the vent regardless of what I did with the dials. And then it suddenly kicked on and worked as expected when I accelerated up the hill.
Old 06-18-2020, 09:15 AM
resharp001's Avatar
Then yes, you are talking about the actual blower, not necessarily the ac or heat. We seem to have some finicky blowers. I had to replace mine about 6 months after buying my jeep brand new back in 2013. Every once in a blue moon the blower will cut out for 10 seconds or so and come back just like nothing happened. If this is something that continues happening, I think I'd look at the blower motor itself. I'd think less likely that it would be the control switch or fan resistor (what controls the fan speed setting when you turn the knob). I think for now I'd cross my fingers and hope it was just a one-time odd occurrence. It seems back when I had to have mine replaced, it was cutting in and out fairly often.
Old 06-18-2020, 11:37 AM
BrettB's Avatar
Thinks for the tip! The blower did sound like this video a few weeks ago, so looks like it might be on it's way out.
Old 06-18-2020, 11:39 AM
resharp001's Avatar
I have not dug into mine, but I believe, from a different thread, you're just talking a ~$70 part, 3 bolts, and an electronic connection, so not a difficult swap if that is the case.
Quick Reply: Aircon(and heat) wasn't working this morning
