View Poll Results: How is your Automatic transmission treating you?
I have NO problems, my transmission works great
85.24%
I am starting to have problems requring a visit to the dealer
9.84%
My transmission is a constant problem and has already been to the dealer
4.92%
Voters: 1199. You may not vote on this poll
Automatic JK Transmission Problems POLL
Old May 21, 2008 | 11:26 AM
  #61
SB08JK's Avatar
Originally Posted by 33 williys 77
I myself was worried about that, please do keep us informed
33
I contacted Chrysler and got nowhere regarding a trans cooler. They said I must go to the local dealer I use for service for answers on warranty.
I contacted Faricy Jeep, the closest dealer to me and likely the one I will be using. I talked to a couple people in service and was told not only will it NOT harm the warranty, they STRONGLY encourage a transmission cooler in the JK. They stated at their dealership, a transmission cooler is something all auto's should have. They said currently there is no MOPAR part specifically for the Wrangler and ANY aftermarker trans cooler would do. They offered to install it for me for 2 hours labor, or about $200.
I was also told that it would not void my warranty if I did it myself, or I had a trans shop do it for me, assuming they do it correctly (there is the catch).
That's the info I have so far. Who knows if they really will stand behind it, but it sounded really good. Each dealer is different. I was expecting them to say no, instead they said it was a really good idea.
Without saying it in words, I got the impression they are aware these transmissions run way too hot.
My suggestion is this. You have your own service advisor at your dealership, each of us are assigned one. Talk to your service advisor AND your service manager FIRST...then move forward with a friendly dealer.
Old May 21, 2008 | 11:35 AM
  #62
SabrToothSqrl's Avatar
Default wow
for $200 i'll install it and wash your car too!
Old May 21, 2008 | 01:45 PM
  #63
derff96963's Avatar
Originally Posted by Hellbound13
Look at the poll results. 25/150 is still an alarming number of tranny problems .
Not it isn't really alarming.
You have to realize that most of the people on this forum are here because they have a problem. So any results here will more than likely be skewed toward the "problem" side.
The second thing you need to realize I bet there are quit a few on here that have more than one screen name. I can't count the number of times you have multiple posts of the exact same problem in one day by "different" people.
There is a third problem with these number also, some of the responses are more than likely due to someone not liking how the tranny shifts saying something is "wrong" with it. Mine shifts "Odd" but I know its the way its programed to shift. There is nothing wrong with it.
If you factor these three things in I am actually surprised it is as much of a landslide for no problems as it is.
Old May 21, 2008 | 04:30 PM
  #64
cadmanaz's Avatar
Default Spoke too soon??
I initially voted that I was not having any issues. But now not so sure....
Can anyone help with this?
Whenever I shift from (P, R, D) to (P, R, D), I hear a very brief noise that sounds like clicking. At least "clicking" is the closest way I can describe it.
There's no clunk or jerking of the Jeep. In fact, WHILE it's making this clicking noise, the tranny GETS in gear, because I can feel it move forward or backwards (depending on which gear I'm shifting into).
To make it simple, here's the way it happens:
1. Apply brake pedal
2. Shift lever to (P, R, or D)
3. ** Clicking ** starts
4. Tranny engages into desired gear
5. ** Clicking ** stops
Other than all of that, it drives real well. No dings while off-roading or at any other time. No diagnostic codes that need to be taken care of. I AM in stop-and-go traffic, but it's always in D.
Any thoughts before I call my service tech??? I've 11,000 miles on it and have not had to call him yet.
Thanks for any help!!!
Old May 21, 2008 | 04:40 PM
  #65
derff96963's Avatar
The clicking is just what you said, the tranny getting into gear. It is perfectly normal unless it is really really loud.
Old May 21, 2008 | 04:44 PM
  #66
Rub61's Avatar
Have 1200 mi. on my Rubicon and trans surges when backing up my driveway with the boat attached (19 ft. Bayliner)???? No problem in Drive but reverse doesn't like the extra load.
Old May 21, 2008 | 05:05 PM
  #67
derff96963's Avatar
Does your boat have a surge brake? What is the weight of the boat and trailer combo?
Old May 21, 2008 | 05:14 PM
  #68
33 williys 77's Avatar
SB08JK
Thank you Sir for your response
I will take your advice and talk to my service advisor, I'm also looking into mounting a frame rail heat exchanger or a Plate trans cooler, what I want to do is stay away from the AC condenser if at all possible, maybe mounting plate cooler behind the radiator.
Thanks again for your input !
33
Old May 21, 2008 | 05:56 PM
  #69
Rub61's Avatar
No surge brake on boat and it weighs approx. 2500 lbs. notice surging most when going over rounded curb going onto driveway.
Old May 21, 2008 | 06:00 PM
  #70
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
18,000...no issues yet
