Backup camera
Old Nov 24, 2013 | 03:32 PM
rokclimbertx's Avatar
Default Backup camera
Just got my 09 JKU and am wondering if this is the backup camera.... if not what is it?
Sent from my SPH-L710 using Tapatalk
Old Nov 24, 2013 | 03:39 PM
11rubiwannabe's Avatar
Looks like it... home job
Old Nov 24, 2013 | 03:48 PM
simadownow6988's Avatar
Yup, looks like a backup camera with IR installed in place of the lock cylinder... Definitely a different location than Ive ever seen..
Guess I'll have to follow the cables, it's currently not working.
Thanks for the help.
Old Nov 24, 2013 | 03:57 PM
That concerns me a bit, have to double check that out locks now too.
Old Nov 24, 2013 | 04:18 PM
rdavi's Avatar
It is a camera as others have said. I just added a camera myself. Pull the closest tail light check the wiring there. Typically the camera is powered by the rear backup lights. Also what is your headend radio? Unless you have a mirror monitor then the monitor is your headend unless they swapped out an aftermarket unit for the original one.
My 0.02
Old Nov 24, 2013 | 04:31 PM
Head unit is a nav/ dvd player. Not sure of the exact designation. The settings have a camera option that I enabled but never got anything but a black screen when in reverse..
Old Nov 24, 2013 | 06:27 PM
rdavi's Avatar
Check wiring.
Trace the wires find the video cable. If the camera has an RCA connecter the plug it into a test monitor to see if the camera is sending an image. Again check the camera power. You are assuming the camera works. From the quality of the camera install I question if the camera works. Also send a different signal to the monitor. Set up a test with an old DVD or similar source an see if it displays
Old Nov 25, 2013 | 05:33 AM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
It's the NSA, you must be on a watch list. That's why you can't use it, it's sending the signal to a van down the road
Old Nov 25, 2013 | 07:25 AM
There used to be a Wi-Fi spot in the neighborhood called fbi surveillance van...
