Dealer fixed my soft top leak....
Old Apr 21, 2009 | 04:52 AM
BaltChief's Avatar
Default Dealer fixed my soft top leak....
So yesterday it is raining big time all day. I am in sales and spend the day in my Jeep.....getting tired of getting soaked I stop by the dealer to give them shit. They tell me they have figuired out the leak.
They took a washer and placed it under each of the 2 bolts that are hand screwed down on the door surrounds....no more leak. Dealer said that this puts just a bit more pressure on the door frame and the top to create a better seal....I drove the rest of the day and stayed dry....
Hope it helps you all out.....
Old Apr 21, 2009 | 05:23 AM
BaltChief's Avatar
Originally Posted by planman
So the 2 pins/bolts with the plastic knobs that secure the door surrounds to the roll bar?
Do the washers go between the pin and the door surround, or do they go between the roll bar and the door surround?
How thick are the washers? Did they use metal or rubber?
Thanks for the help. Please post pics if possible.
Used 1/16 inch thick plastic or nylon washers between the door surround and the roll bar, one for each pin. I guess it lifts the rail just a bit into the door seal?
But I do know I was dry after they put them in
Old Apr 21, 2009 | 05:36 AM
greenamphibious's Avatar
they tried that with mine... worked for about 2 weeks. I used Marine grade weather stripping between the top and door surround and in the corner of the door frame and have been bone dry for a month
Old Apr 21, 2009 | 06:11 AM
cgtweet's Avatar
Default re
Thanks Balt... was your leak just at the corner? I am going to try this fix. I gave up on my dealership. Got tired of the foam kits and leak seems to just get worse. I will let you know if it fixes mine.
Greemamp... can you post a pic of your self-fix?
Thanks,
Vince
Old Apr 21, 2009 | 06:18 AM
racer83l's Avatar
which leak are you referring to??? mine in particular leaks on the passenger side only right onto the top of the door handle.
Old Apr 21, 2009 | 06:21 AM
Piginajeep's Avatar
mines does the same, both sides. Same on my green one too
Old Apr 21, 2009 | 06:34 AM
cgtweet's Avatar
Default re
LOL... we all have same leak. I am going to try the washer fix...
Old Apr 21, 2009 | 06:44 AM
BaltChief's Avatar
My leak was the one that fell right on the door handles......
Boy it feels good saying..."was"....I hope it stays fixed.
Old Apr 21, 2009 | 07:02 AM
PA RUBICON's Avatar
post a pic of this if you don't mind.
Old Apr 21, 2009 | 07:17 AM
https://www.jk-forum.com/forums/stock-jk-tech-12/i-fixed-my-fuggin-leaky-top-80318/
