Dealer fixed my soft top leak....
Old Apr 21, 2009 | 07:42 AM
heepenjim's Avatar
This does work I did that to mine and have not had a leak. However check them after you go wheeling the flexing tends to make them come loose.
Old Apr 21, 2009 | 10:15 AM
cgtweet's Avatar
Default re
Thanks for the link Green. Gonna try the washers... then the weather strip if needed. The water does get a bit much some days...:(
Old Apr 21, 2009 | 01:28 PM
BaltChief's Avatar
Here is a pic of the washer....it is a 3/8 hole and fits quite snug over the bolt, it is 3/32 thick. If you take the door surrounds off you will see they are in a "C" shape that goes around the rollbar. The washers are between the top of the roll bar and the top of the "C"....it is a tight fit.
Just a nylon washer....
I think what it is doing is securing the door surround. Without the washer the surround rotates just a bit, with the washer it is solid. That could also explain why I had the leak sometimes and sometimes I did not. It all depended on where the surround was rotated....I'm just guessing here....but still no leaks.....maybe the dealer finaly got one right.
Old Apr 21, 2009 | 01:43 PM
saltman's Avatar
I'll give it a try when I get the Jeep back from the dealer. Thanks for posting.
Old Apr 21, 2009 | 05:00 PM
JackMac4's Avatar
I dont understand where you're talking about putting these washers at? Could you post a pic of them installed or give a better description for the slow kids like me?
Old Apr 21, 2009 | 05:12 PM
greenamphibious's Avatar
unscrew door surrounds and place it between the surround and the roll bar.... thats what was done to mine
Old Apr 21, 2009 | 05:22 PM
BaltChief's Avatar
Thank you.....I knew what I wanted to say......just couldn't get it from my mind to the computor keyboard...
Old Apr 21, 2009 | 05:25 PM
Old Apr 21, 2009 | 06:46 PM
interceptor_1972's Avatar
Originally Posted by Piginajeep
mines does the same, both sides. Same on my green one too
That's exactly where mine is too; on occasion, though very rarely, I noticed a few drops on the rear door handles too.
Thanks for the info guys! Gonna try that and see how it goes; 'course now that the sun's been out for a few days, may not see much rain here.
Old Apr 22, 2009 | 03:23 AM
PA RUBICON's Avatar
guess i am slow too.
ok. i know the surrounds and knobs. can this be done with the top on? or do you have to remove it, fold it back? do you have to take the roll bar padding off? sadly , guess i need a step by step.
