Diff. Fluid Change Question
Old Nov 3, 2009 | 07:47 PM
Hellbound13's Avatar
Default Diff. Fluid Change Question
I am about to change my diff. fluid and Im switching to synthetic. (Mobil 1)
My question is, will I have to stick with synthetic from here on out?
Old Nov 3, 2009 | 09:26 PM
B11's Avatar
B11
No but why would you want to change back?
Old Nov 4, 2009 | 05:59 AM
db09JKU's Avatar
Originally Posted by JK-Holiday
I am about to do this on my JK this weekend. Do I need to add the LSD additive to this as well or just the Mobil 1. I'm using 75/90 full synthetic. I know on the web site it says "compatible" with most LSD's. I'm sure the Trac-loc in the D44 rear is compatible. I don't want to ruin the clutches I guess. Can't afford a new locker system right now.
Great write up. http://project-jk.com/jeep-jk-write-...hange-write-up
Old Nov 4, 2009 | 06:40 AM
saltman's Avatar
Pretty sure the difs come with synthetic from the factory.
Old Nov 4, 2009 | 06:47 AM
Because in case my diff goes under warranty the dealer is going to put the regular stuff back in.
Old Nov 4, 2009 | 06:50 AM
racer83l's Avatar
the MOPAR fluid is synthetic... thats what I use... I would imagine thats what they fill it with initially
Old Nov 4, 2009 | 07:16 AM
If the Mopar is synthetic why does it require a LSD additive?
Also anyone know why its costs so much more than say the mobil 1?
Old Nov 4, 2009 | 07:50 AM
ronjenx's Avatar
Two people in this thread have said the original stuff in the diffs is synthetic. Could be, but I would have to see the bottle to believe it.
The MOPAR stuff is synthetic only if it says "synthetic" on the bottle.
Initially, they come with Mopart Gear & Axle Lubricant (SAE 80W-90) (API GL-5), which is a general purpose GL-5 gear oil. I don't believe it says synthetic on those bottles.
Old Nov 4, 2009 | 07:52 AM
saltman's Avatar
This is what the manual says for 09.
Axle Differential (Front) MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
Axle Differential (Rear) 226 RBI (Model 44) - MOPAR Gear & Axle Lubricant (SAE 80W-90) (API
GL-5) or equivalent. For trailer towing, use MOPAR Synthetic Gear & Axle
Lubricant (SAE 75W-140) or equivalent. Models equipped with Trac-Lok™
require an additive.
I think the 07 was different. I think it said 44s had the synth in it and the towing statement wasn't there. I will have to check. Maybe I'm remembering my TJ/LJ info.
Old Nov 4, 2009 | 07:55 AM
racer83l's Avatar
here you go.
