Hard top cracks from fasteners
Old Aug 15, 2008 | 12:36 PM
  #31
RedneckJeep's Avatar
Count me in!
Old Aug 15, 2008 | 12:43 PM
  #32
Seir's Avatar
Originally Posted by Woods
If I recall correctly (doubtful) the plate that I designed is 2" X 1.5" of .125" stainless.
Nice. Hope you have something available then before winter sets in
Thanks.
Old Aug 15, 2008 | 01:46 PM
  #33
Maybe it's just me but it looks like it needs support under the top?
Old Aug 15, 2008 | 04:49 PM
  #34
cmpmacchia's Avatar
Went to the dealer and they won't cover it. Count me in for a fix!
Old Aug 15, 2008 | 05:07 PM
  #35
sixt7gt350's Avatar
You've never removed the top, so it's cracking under factory torque, and they won't cover it?!?!?!
That is a bunch of bullsh!t right there!
For those of us that remove and re-install our tops frequently, I could understand, but.....
Old Aug 15, 2008 | 05:35 PM
  #36
Rubimon's Avatar
My top hangs most of the year. I only finger tighten mine. But I bet the plates would look nice anyway and a good preventative measure.
Old Aug 15, 2008 | 05:44 PM
  #37
CJK's Avatar
CJK
Mine has several cracks Only time I took the rear off was to uninstall the soft top. Snugged the bolts with a small ratchet one handed lightly to avoid this very problem which I anticipated based on my old CJ hardtop. I've only done mild off-road but hell, I hear it creaking and popping every morning when I back out of the driveway. When I take the JK west to Moab or CO I guess I'll install the soft top - I doubt the hard top would take a week of trail flexing without structural damage.
Count me in for a set of plates.
Old Aug 16, 2008 | 09:08 AM
  #38
I'd say that it definitely wouldn't hurt.
I finally got my backseat removed from my two door and I am getting ready to design and build a platform in the back that rests on the ledge of the hard top. After reading all of the posts I thought maybe I should address this problem even though I don't have cracks at this time. I plan on using 1 1/2" X 1 1/2" aluminum to run parallel and on top of the ledge of the top.
Now the question is: How soon are you going to have your fix available. Also I didn't see any pictures of your design but by the pictures of the problem the top has stress from above that needs to be relieved by a shim below the top. Should your fix not be ready available would a fender washer below the top serve the same purpose so as not to hold up my project.
Also does anyone know if I should get longer bolts or will the factory bolts have enough bite after adding a fender washer below and 1/8" angle above.
My Thanks to anyone for any added imput, GRIZZ
Old Aug 16, 2008 | 09:11 AM
  #39
GadgetPhreak's Avatar
I'm in for these plates Woods.
Old Aug 16, 2008 | 09:32 AM
  #40
sixt7gt350's Avatar
I inspected mine a few minutes ago when I took the top off. (many days of rainless bliss in the forecast)
Two are cracked, the rearmost right side ones.
My cracks aren't quite as bad as the pics.
I only tighten my bolts with a driver and a twist of the wrist. (no ratchet or other leverage)
I expected something like this could happen after many years of use, but not in less than a year and not to be not covered by warranty. (especially since the cracks appear to be the norm, not the exception)
