View Poll Results: How many problems have you had with your Jeep?
None
519
43.39%
One
259
21.66%
Two
136
11.37%
> Two
282
23.58%
Voters: 1196. You may not vote on this poll
How problematic is your Jeep?
Well, I never included the recalls or TSB's either... throw that in and you add:
Slow start (cam position sensor).
Brake Recall
So that brings me to 4. I still need the clutch fixed (sqeak) for number 5.... Also, the muffler is rotting away (it's only 6 months old... i shouldn't have holes in the muffler yet....) 6....
Brake Recall
It took 100th of a second to realize I was over 2 so no brainer. Nothing the toyota trucks I've had. I love being able to modify but it's wearing me down.
Steering stabilizer
Electronics 70% failure
Woobles and shimmys
Squeaky drivers door pilar
Horn barely works
should I continue...na I'm over 2
Steering stabilizer
Woobles and shimmys
Horn barely works
I have the timing cover leak, a power steering hose is leaking and my steering stabilizer is leaking, so I had to say >2. I don't look for warranty on the stabilizer, because it has a very small dent near where the piston goes into the can. With just barely 3000 miles on it, they better fix everything else.
You'll always see the people with problems posting more, because they're either venting or trying to find a solution to a problem. Occasionally, you'll post that things are great and there are no problems, but there's often no reason to post for that purpose.
No real problems here, aside from the recalls. No leaking top, no clunky steering, etc. I do have one noise I'm having the dealer look at next oil change, but other than that it's been smooth sailing.
Although, the whole jeep rattles as if it's 10 years old, but I'll blame that on the cold weather playing havoc on all the cheap plastic. When it's warm out and the top is off, the wind noise will drown out my rattles
LOTS... mostly due to the fact that i wheel the piss out of it... mostly covered under warranty
- throw bearing in clutch
- brake flash and all recalls
- radio flash
- mudules, switches and computers... water damage ( my dime... 1800 bux OUCH)
- rear driveshaft
- tranny and TC leaking
- evap cannister broken
- diff covers leaking
- MANY, MANY steeing stabilzers, i have resigned my self to the fact that i have to change it after every time i wheel... (my dime) it is in the stupidest spot in the world... only thing lower is the diff... i am thinking highsteer will fix that
i think that is it... but i am sure there is more
all warrantied except the one stated
- radio flash
- rear driveshaft
Where is the >5-10 on the poll
lets see.
The dredded top
wheel speed sensor
cam shaft sensor
door seal ruined my carpet.
drivers door lock
transmission seal
rear cv joint
leaky rear window gasket
i can't remember them all. I think i may have a lemon but i figure that if i replace everything i will have a good jeep maybe.........
lets see.
The dredded top
wheel speed sensor
cam shaft sensor
drivers door lock
transmission seal
rear cv joint
