JK Manual Transmission Automatic Throttle Control at 4 Lo Idle - No more stalling
Old Feb 27, 2010 | 09:19 PM
warlord's Avatar
is this true for 07 6-speeds as well?
ive stalled climbing a hill with 4:10 and sahara wheels
Old Feb 28, 2010 | 02:26 AM
toymaster's Avatar
but the rubi has an unfair advantage with the 4:1 low range. It is almost like it was designed to crawl.
Old Feb 28, 2010 | 07:46 AM
warlord's Avatar
its an x actually i should have put that in there
Old Feb 28, 2010 | 10:46 AM
highoctane's Avatar
I know mine wont stall in 1st/low. I have 35s with the stock 4.10 gears, so my crawl ratio has gone down a hair over stock with the taller tires. If im coming up on an obstacle that idle/1st/low is to fast for, I put on the brakes, and it slows w/o stalling. Hell I pushed the brake pedal to the floor and the damn thing just get trying to go, overpowering my brakes, w/o stalling.
Old Feb 28, 2010 | 11:17 AM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Originally Posted by Renegade JK
and I though I was the only one thinking this. Just brake and clutch, thats I wheel my JK. Very hard to stall like this. Feels like a have the same gear ratio as my old Jeep (4.56's + Atlas 4.3:1 and 35's) where as now Im runnng 5.13's in the axles and only a 2.73:1 low range (stock X transfercase) and 35's
Thanks for the input. Good to know that this works on an X too.
That's what I have and according to the post above, it shouldn't matter X or Rubi. As has been previously posted, this is not 100% full proof, but it's a REALLY great tip when a crawl is needed.
I'll be interested to hear from an Atlas owner. My guess is that the lower your rig is geared the better that this will work.
Old Feb 28, 2010 | 12:07 PM
PG-JKU's Avatar
Did this with my 6 speed Sahara yesterday. Could hardly hold it in place with the brakes. Great tip. I heard that to stop you switch the ignition off. Can even stay off the clutch completely since it will start in 4Lo without the clutch AND in 1st gear.
Old Feb 28, 2010 | 04:11 PM
fasthorse67's Avatar
Simply amazing. I had no idea my Jeep would do this. My wife might even be able to drive it now that I know it's very hard to stall. The last time I tried to teach her was in an extremely modified '84 Mustang. She ended up getting it sideways and almost crashing into a pole. I said NEVER again! But now I'm thinking big, underpowered, almost impossible to stall. Maybe I'll try to teach her one last time.
Old Feb 28, 2010 | 05:05 PM
dmhines's Avatar
Doubt it would work in my X with the standard T-Case and 3.21 gears!
Old Feb 28, 2010 | 05:14 PM
PG-JKU's Avatar
Try it. 3.21's here too. And regular T-case. And it works.
Old Feb 28, 2010 | 05:21 PM
rome07JK's Avatar
right on worked for me...6 speed 3.21s
