mirror mirror
Been thinking about grabbing one of these from http://www.dietechoffroad.com/produc...rorbracket.htm
they're a sponsor now
and this is pretty slick
pics of my H-D mirror mounted. It's the tapered mirror in black - I think I paid $35 for it. There are 2 versions of the same shape - long stem and short stem - mine is the short stem.
Here is a pic of the mirror from the H-D website.
It is small, but I have no problem seeing what's behind me. No vibration at all when it is mounted.
JD
JD
I ran this setup last summer. It was actually exactly the same model mirror as HJ97TJ shows in post 11 above.
You don't need any tools to install/uninstall it. If you use the mirror itself for leverage when tightening, you can easily hand-tighten it enough to keep it solidly in place even at highway speeds. You'll see what I mean when you install it.
Short story: no wingnut needed.
Right (passenger) mirror
55077966AC -- 2WD/4WD, 2DR/4DR
55077967AC -- 2WD/4WD, 2DR/4DR, with swingaway
55077968AC -- 4WD (RHD), 2DR/4DR, manual remote control
Left (driver) mirror
55078131AC -- 2WD/4WD, 2DR/4DR, manual remote control
55077969AC -- 4WD (RHD), 2DR/4DR
55078024AC -- 4WD (RHD), 2DR, with swingaway
I think these part numbers refer only to the assembly. The glass is separate as are the bolts. I can get those part numbers for you if needed too.
I know that the short arm version that I have wouldn't work for a pass side mirror. The long arm version might.
In NJ, you only have to run 2 mirrors, (including your interior rear view) so I won't be getting one for the pass side.
JD
Not the greatest pics for comparison, but for anyone who wants to see a side by side comparison:
Full Doors:
Half Doors:
JD
I got the Rugged Ridge mirror replacement brackets and the passenger side is useless. But i like it. it takes getting use too but it just makes doorless driving easy. Plus its easy to move the mirriors back to the stock position on winter months
