Mopar Transmission Cooler Kit
Old 04-04-2012, 01:57 PM
  #101
AirJordan613's Avatar
Here are the pics of my new mopar trans cooler!
ID:	299669   Click image for larger version
ID:	299670   Click image for larger version
ID:	299671   Click image for larger version
ID:	299672   Click image for larger version
Old 04-04-2012, 02:45 PM
  #102
Jeepnut67's Avatar
Thumbs up
Very nice!
Old 04-04-2012, 03:47 PM
  #103
jdo
jdo's Avatar
I get mine tomorrow installed, try to get pictures of the unit
Old 04-04-2012, 04:33 PM
  #104
Fenrir's Avatar
Sweet! If mine is installed there, maybe I can still install my tuffy hood lock :-)
Old 04-04-2012, 04:37 PM
  #105
ronjenx's Avatar
After a cooler installation, it may be handy to know the proper fluid level at various temps in the transmission sump.
For those who have a transmission sump temperature gauge, (AeroForce, or a sender in the pan), the following information is taken from the factory service manual:
Old 04-04-2012, 05:15 PM
  #106
Mine is definitely overfilled then. Not sure how much that matters but I don't think it's anything to worry about. Better then not enough.
Old 04-04-2012, 05:24 PM
  #107
ronjenx's Avatar
Normally it's not a problem. It's when it overheats or foams, that the level shoots up and comes out the vent or the dip stick tube.
We know what that can lead to...
Old 04-04-2012, 06:13 PM
  #108
joe002's Avatar
AirJordan613 - Thanks for posting the pics!
ronjenx - thanks for the dip stock info. I have an AeroForce too. I didn’t know that had the different temps in the FSM. How are your temps looking now? Also, speaking of cooling what is the “normal” max temperature you should see?
Old 04-04-2012, 06:25 PM
  #109
ronjenx's Avatar
My temps seem a little lower than before the cooler. It's hard to say with any real certainty because the ambient temperatures are still in the 30's to 50's (°F). I won't know how effective the cooler is until this summer.
Regarding the "normal" max temperature, I'm not too worried until the fluid rises above 180°F to 190°F. That's when I do what it takes to bring the temp back down.
Now that I have installed the cooler, I'm hoping it never gets that high.
Old 04-04-2012, 06:29 PM
  #110
joe002's Avatar
Thanks, I thought 180-190 was the max you wanted to hit.
I'll be interested in hearing how yours does this summer when you're out wheeling it.
Quick Reply: Mopar Transmission Cooler Kit
