Normal running temp..
Old Oct 23, 2013 | 10:26 AM
Mikes07JK's Avatar
Default Normal running temp..
I just bought my first jeep. Mine runs directly in the middle of the temp gauge. Is this normal?
Old Oct 23, 2013 | 10:27 AM
Maertz's Avatar
sure is.......
Old Oct 23, 2013 | 10:29 AM
2009rockymountain's Avatar
Yup that should be right..it will rise slightly if your offroading going slow (less air) but just a hair..any more and somthing is wrong
Old Oct 23, 2013 | 10:40 AM
Mark Doiron's Avatar
If you have an Android device, download Torque and pick up an OBD/BT adapter and you can monitor the actual temperature. Mine generally runs 194-204 degrees. Which is about midway on the unmarked OEM gauge.
Old Oct 23, 2013 | 10:46 AM
Mark. Iv looked at that app before..sorry to be off topic.but how u like it? Features?
I hate how oura dashs have very lil info
Old Oct 23, 2013 | 12:04 PM
Mikes07JK's Avatar
Thanks for the info fellas. I appreciate it
Old Oct 23, 2013 | 03:10 PM
I like it a lot. No oil pressure gauge (because there is no oil pressure sensor in the JK, just a switch), but otherwise tons of info. I use it on my Nexus 7. I added an oil pressure gauge myself and now feel reasonably well instrumented.
Old Oct 23, 2013 | 03:12 PM
ronjenx's Avatar
What have you observed for oil pressure readings? (@ idle; @ 2,000 rpm, @ 3,000 rpm)
Old Oct 25, 2013 | 10:37 AM
Jiblet's Avatar
On mine, idle ~650, full op temp, the pressure hovers around 11.
At 70 mph, 2100 rpm, the pressure is about 38 psi.
My oil temp gauge is wonky lately but I'm sure I was at full op temp after a 20 mile drive on highway.
Old Oct 25, 2013 | 12:26 PM
JeepaRoo's Avatar
doesnt the 3.6 have oil pressure on the JK? or is it just a switch like the 3.8
-Christopher
