Normal running temp..
If you have an Android device, download Torque and pick up an OBD/BT adapter and you can monitor the actual temperature. Mine generally runs 194-204 degrees. Which is about midway on the unmarked OEM gauge.
I like it a lot. No oil pressure gauge (because there is no oil pressure sensor in the JK, just a switch), but otherwise tons of info. I use it on my Nexus 7. I added an oil pressure gauge myself and now feel reasonably well instrumented.
What have you observed for oil pressure readings? (@ idle; @ 2,000 rpm, @ 3,000 rpm)
At 70 mph, 2100 rpm, the pressure is about 38 psi.
My oil temp gauge is wonky lately but I'm sure I was at full op temp after a 20 mile drive on highway.
