Oil Filter Recommendation
Old May 28, 2007 | 06:52 AM
kdubber's Avatar
Default Oil Filter Recommendation
Can anyone recommend a good brand and part number, i.e., Fram??
Thanks -- and happy Memorial Day all -- with a heartfelt THANK YOU to all our veterans past and present!! Grateful for our FREEDOM that you protect!
Kdub
Old May 28, 2007 | 07:10 AM
IGOFSHN's Avatar
You are going to get a lot of this is the best and that is the worst, especially against fram. I've used fram for almost 35 years and have never had a problem. Any place that sells filters will have the correct part # for which ever you want. I always get mine at wally world.
Old May 28, 2007 | 07:14 AM
tolh13's Avatar
here is a good post:
FuLcRuM
Member
FuLcRuM is offline
Posts: 55 Oversized Oil Filter!
I tried searching today but didn't find what I wanted so I thought Id share my results from all my research today.
Stock Mobil-1 oil filter for the JK is M1-102
when I looked at it the other day I was not impressed so knowing that it's fairly common to use a larger filter I searched until I found one for us.
Mobil-1 M1-209.
This is a direct fit but is about twice as long, I just changed the oil tonight at 3k with 5-20 Mobil-1 and the M1-209 oversized filter. It pokes out a little but fits fine.
While searching online I found info from another forum where a person called and actually asked a mobil tech about the 102 and 209 and it was confirmed by the tech that the thread size, anti-drain back valve and everything were the same it's just longer.
I made a quick cross referance with some of the common filters and the larger equivalent. I also found that the larger filter is actually the Stock 3.7L Commander filter.
--------2007 Jeep JK--------
----Make------Stock------Oversize
Amsoil--------EAO57------EAO34
Fram---------PH3614-----PH3600
K&N---------HP-1002-----HP-2009
Mobil--------M1-102------M1-209
Mopar--------L-335----------???
Napa----------1348---------1516
PureOne----PL10241----PL20195
Purolator----L10241------L20195
Wix------------51348-------51516
__________________
07 Unlimited Sahara
Teraflex 2.5" BB | Crager Soft 8's 17x8
Old May 28, 2007 | 07:17 AM
L8TRKDS2's Avatar
Have you seen this?
http://minimopar.knizefamily.net/oilfilterstudy.html
Old May 28, 2007 | 07:26 AM
Zylfrax791's Avatar
With the K&N oil filter you can use a 1 inch wrench or socket which seems really practical to me.
Old May 28, 2007 | 07:48 AM
IGOFSHN's Avatar
Who uses a wrench. If you need a filter wrench, you have it on too tight.
Old May 28, 2007 | 10:51 AM
kdubber's Avatar
Default Filter
I Fram'd it...............thanks!
Old May 28, 2007 | 11:03 AM
bodybrdng's Avatar
curiosity.. do putting a different oil filter in make that much of a difference? Is it worth it?
Old May 28, 2007 | 11:50 AM
tolh13's Avatar
better oil makes a difference(Mobil one)on how long you can run on it.so if you run it longer then 3000 mile you need a better oil filter.I do not think your going to get one answer that ever one will agree on for oil,oil filter and how many miles for oil changes.I run Mobil one with a Mobil one oil filter for 7500 miles and change the filter at 3750 miles and 7500.right or wrong i don't know.I sure i will buy a new wrangler in 3 to 5 years and never know if help or hurt my jeep but it's worked for my for the last 15 years of so.
Old May 28, 2007 | 05:06 PM
NYRacBaller's Avatar
Is there really such a place outside of Chevy Chase movies??? I am sure there is just don't have one around me.
