Parking brake change?
Old Nov 22, 2016 | 12:04 PM
  #21
JK-Forum Editor's Avatar
JK-Forum Editor
Default How-To Tuesday
Perfect topic for How-To Tuesday...
Jeep Wrangler JK 2007 to 2015 How to Repair and Replace Parking Brake - Jk-Forum
Old Nov 22, 2016 | 11:38 PM
  #22
jeepmojo's Avatar
Default pita
mine were shot after 3 years when removing the drum the pads just fell apart and 2 were not even there just floating around scrap. its not a easy task. The pad system needs to be assembled with both top and bottom springs on, and then pulled into place. otherwise youl never get those springs on after due to the fact one of the springs is behind parts behind, not allowing good access to the hole it clips into. just a tip
Old Nov 23, 2016 | 06:18 AM
  #23
OverKill's Avatar
Vet Army
I just replace my pads and drum, planning on replacing the shoes. They looked fine to me. I asked the shop advisor (ASE mechanic), he said you do not have to pull the axle, but it sure makes it real simple. But mine looked fine, so I moved on. Hope that helps.
Old Jan 20, 2017 | 06:53 PM
  #24
Ceruzziracing's Avatar
Just an FYI, if you hear a grinding noise, could very well be a bent axle flange rather than a brake issue. Just my .02
