Post Manual Programming Features with Sequences - Enable / Disable
Old Apr 22, 2012 | 09:03 PM
Rooster76's Avatar
ABOUT POST
Most of this information comes from the 2012 4th Edition User Guide PDF. These program sequences should work with almost any JK. It seemed to be a nice idea to have them all in one place where you can easily run through them. I did my best to put the section and page number from where the feature sequence was found in the manual, or my source. There are some programming features that are now being left out of the user manual (like remove the door chime reminder). I did my best to find those to make this more complete. I would like to thank DesertJeepin for his post on --> Disable/Enable feature codes/sequences. That one was getting long and harry so I decided to condense it.
NOTE: Most of these sequences are set to toggle. So just do it a second time to reset it.
__________________________________________________ ____
Remove Seat Belt Reminder Chime -Enhanced Seat Belt Use Reminder System
(BeltAlert_) –Removed from current manual – Says to go to dealer.
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the
ON/RUN or START position. Chrysler Group LLC does
not recommend deactivating BeltAlert.
1. Turn the ignition switch to the OFF position, and
buckle the driver’s seat belt.
2. Turn the ignition switch to the ON/RUN position (do
not start the engine), and wait for the Seat Belt Reminder
Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 10 seconds, ending with the seat belt fastened.
Remote Key Unlock All On First Press -22 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
1. Press and hold the LOCK button on a programmed
RKE transmitter.
2. Continue to hold the RKE transmitter LOCK button
for at least four seconds, but not longer than 10 seconds,
then press and hold the RKE transmitter UNLOCK
button.
3. Release both buttons at the same time.
4. Test this feature while outside of the vehicle by
pressing the LOCK/UNLOCK button on the RKE transmitter.
NOTE:Pressing the RKE transmitter LOCK button
while you are inside of the vehicle will activate the
Vehicle Security Alarm. Opening a door with the Vehicle
Security Alarm activated will cause the alarm to sound.
Press the RKE transmitter UNLOCK button to deactivate
the Vehicle Security Alarm.
5. If the desired programming was not achieved or to
reactivate this feature, repeat the above steps.
NOTE:Pressing the LOCK button on the RKE transmitter
while you are inside the vehicle will activate the
Press the UNLOCK button to deactivate the Vehicle
Security Alarm
Sound Horn On Lock-24 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
This feature will cause the horn to chirp when the doors
are locked with the RKE transmitter. This feature can be
turned on or turned off. To change the current setting,
proceed as follows:
• For vehicles equipped with the EVIC, refer to “Electronic
Vehicle Information Center (EVIC)/Personal
Settings (Customer-Programmable Features)” in “Understanding
Your Instrument Panel” for further information.
• For vehicles not equipped with the EVIC, perform the
following steps:
1. Press the RKE transmitter LOCK button for 4 to
10 seconds.
2. While the LOCK button is pressed (after four seconds),
press the RKE transmitter PANIC button. Release both
buttons.
The “Sound Horn On Lock” feature can be reactivated by
repeating this procedure.
To Turn Off Flash Lights With Lock -25 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
This feature will cause the turn signal lights to flash when
the doors are locked or unlocked with the RKE transmitter.
This feature can be turned on or turned off. To change
the current setting, proceed as follows:
following steps:
1. Press the RKE transmitter UNLOCK button for 4 to
10 seconds.
2. While the UNLOCK button is pressed, (after four
seconds) press the RKE transmitter LOCK button. Release
both buttons.
3. Test the “Flash Lights With Lock” feature outside of
the vehicle by pressing the RKE transmitter LOCK button
with the ignition in the LOCK position and the key
removed.
NOTE: Pressing the RKE transmitter LOCK button
while you are in the vehicle will activate the Vehicle
Security Alarm. Opening a door with the Vehicle Security
Alarm activated will cause the alarm to sound. Press the
RKE transmitter UNLOCK button to deactivate the Vehicle
Security Alarm.
The “Flash Lights With Lock” feature can be reactivated
by repeating this procedure.
Automatic Unlock Doors On Exit -39 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
The doors will unlock automatically on vehicles with
power door locks if:
1. The “Automatic Unlock Doors On Exit” feature is
enabled.
2. The vehicle speed returned to 0 mph (0 km/h) and the
transmission shift lever is in NEUTRAL or PARK.
3. The driver door is opened.
4. The doors were not previously unlocked.
Automatic Unlock Doors On Exit Programming
The “Automatic Unlock Doors On Exit” feature can be
enabled or disabled as follows:
1. Close all doors and place the key in the ignition.
2. Cycle the ignition switch between LOCK and ON/
RUN and then back to LOCK four times ending up in the
LOCK position.
3. Press the power door unlock switch to unlock the
doors.
4. A single chime will indicate the completion of the
programming.
5. Repeat these steps if you want to return this feature to
its previous setting.
NOTE:Use the “Automatic Unlock Doors On Exit”
feature in accordance with local laws.
AutomaticDoor Locks Programming – Locks all doors at 15mph (removed from current manual, says to have dealer do it)
The “Automatic Door Locks” feature can be enabled or
2. Cycle the ignition switch between LOCK and ON and
then back to LOCK four times ending up in the LOCK
position.
3. Press the power door LOCK switch to lock the doors.
programming.
NOTE: Use the “Automatic Door Locks” feature in
GOT A CHILD SEAT
-56
Automatic Locking Retractor Mode (ALR) — If
Equipped
In this mode, the shoulder belt is automatically prelocked.
The belt will still retract to remove any slack in
the shoulder belt. The Automatic Locking Mode is available
on all passenger-seating positions with a combination
lap/shoulder belt. Use the Automatic Locking Mode
anytime a child safety seat is installed in a seating
position that has a belt with this feature. Children
12 years old and under should always be properly
restrained in the rear seat.
How To Engage The Automatic Locking Mode
1. Buckle the combination lap and shoulder belt.
2. Grasp the shoulder portion and pull downward until
the entire belt is extracted.
3. Allow the belt to retract. As the belt retracts, you will
hear a clicking sound. This indicates the safety belt is
now in the Automatic Locking Mode.
How To Disengage The Automatic Locking Mode
Unbuckle the combination lap/shoulder belt and allow it
to retract completely to disengage the Automatic Locking
Mode and activate the vehicle sensitive (emergency)
locking mode.
Customer Key Programming - 18 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
If you have two valid Sentry Keys_, you can program
new Sentry Keys_ to the system by performing the
following procedure:
1. Cut the additional Sentry Key_ Transponder blank(s)
to match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch. Turn
the ignition switch to the ON/RUN position for at least
three seconds, but no longer than 15 seconds. Then, turn
the ignition switch to the LOCK position and remove the
first key.
3. Insert the second valid key into the ignition switch.
Turn the ignition switch to the ON/RUN position within
15 seconds. After 10 seconds, a chime will sound. In
addition, the Vehicle Security Light will begin to flash.
Turn the ignition switch to the LOCK position and
remove the second key.
4. Insert a blank Sentry Key_ into the ignition switch.
60 seconds. After 10 seconds, a single chime will sound.
In addition, the Vehicle Security Light will stop flashing.
To indicate that programming is complete, the Vehicle
Security Light will turn on again for three seconds and
then turn off.
The new Sentry Key_ is programmed. The Remote
Keyless Entry (RKE) transmitter will also be programmed
during this procedure.
Repeat this procedure to program up to eight keys. If you
do not have a programmed Sentry Key_, contact your
authorized dealer for details.
NOTE:If a programmed key is lost, see your authorized
dealer to have all remaining keys erased from the system’s
memory. This will prevent the lost key from
starting your vehicle. The remaining keys must then be
reprogrammed. All vehicle keys must be taken to an
authorized dealer at the time of service to be
reprogrammed.
Old Apr 22, 2012 | 09:04 PM
Rooster76's Avatar
Post Continued
REMOVE OIL LIGHT -296 UNDERSTANDING YOUR INSTRUMENT PANEL
1. Turn the ignition switch to the ON position. Do not
start the engine .
2. Fully depress the accelerator pedal slowly three times
within 10 seconds.
3. Turn the ignition switch to the LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Clock Setting Procedure
- UNDERSTANDING YOUR INSTRUMENT PANEL 307
1. Press and hold the TIME button until the hours blink.
2. Adjust the hours by turning the right side TUNE/
SCROLL control knob.
3. After adjusting the hours, press the right side TUNE/
SCROLL control knob to set the minutes. The minutes
will begin to blink.
4. Adjust the minutes using the right side TUNE/
SCROLL control knob. Press the TUNE/SCROLL control
knob to save the time change.
5. To exit, press any button/knob or wait five seconds.
The clock can also be set by pressing the SETUP button
and selecting the “SET HOME CLOCK” entry. Once in
this display follow the above procedure, starting at
step 2
HSA Off = Hill Start Assist - 426 STARTING AND OPERATING
If you wish to turn off the HSA system, follow this
procedure:
1. Start with the engine off and vehicle in PARK (automatic
transmission) or NEUTRAL with clutch out
(manual transmission) with wheels straight. Apply parking
brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the
clutch out, rotate the steering wheel 180° counterclockwise
from center.
4. Press the ESC OFF switch four times within twenty
seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise
from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESC
Activation/Malfunction Indicator Light” will blink several
times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off
HSA. Repeat steps 1-7 to re-enable HSA functionality.
Turn ESP OFF COMPLETELY – From Link ->Disable/Enable feature codes/sequences
1. Turn jeep on
2. Set to 4hi
3. Set parking brake
4. Make sure steering wheel is centered
5. Turn wheel to the right, 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, you may hear a chime at 5 seconds(and ESP OFF may show up on the speedo), but keep holding for 7 seconds!!!!
6. Turn wheel back to center then left 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, again, hold for 7 seconds!!!
7. Turn back to center, and hold ESP for 7 seconds.
8. Turn Jeep off
Some of the programming can be done through the EVIC , if you have that installed, instead of strange little sequences.
DETERMINE IF YOU HAVE EVIC: You will see a picture of a door open on your instrument panel, if the door is open, if you have EVIC installed, . If you do not have EVIC you will only see the word, “Door,” displayed.
EVIC PROGRAMING - UNDERSTANDING YOUR INSTRUMENT PANEL 301
Personal Settings allows the driver to set and recall
features when the vehicle speed is at 0 mph (0 km/h)
(manual transmission) or when the shift lever is in PARK
(auto transmission).
Press and release the MENU button until Personal Settings
displays in the EVIC.
Use the DOWN button to display one of the following
choices:
*Language,
*Auto Unlk On Exit,
*RKE Unlock( Remote Keyless
*Entry (RKE) transmitter UNLOCK button)
*Sound Horn With Lock
*Flash Lamp with Lock
*Headlamp Off Delay
*Headlamps with Wipers (Available with Auto
*Headlights Only)
* Key Off Power Delay
*Illumin. Approach( When this feature is selected, the headlights will activate
and remain on for up to 90 seconds when the doors are
unlocked with the RKE transmitter.)
*Hill Start Assist (HSA) — If Equipped,
*Display Units In,
*Nav–Turn By Turn — If Equipped,
*Display Fuel Saver — If Equipped,
*Compass Variance,
*Calibrate Compass
How To Read DTC Error Codes - From Link -> Disable/Enable feature codes/sequences - Page 3
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes. If your Jeep JK Wrangler has logged any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s).
3. If your Jeep JK Wrangler has not logged any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
A list of DTC codes can also be found here LINK-> Disable/Enable feature codes/sequences - Page 4
Old Jun 25, 2012 | 09:30 AM
Rooster76's Avatar
Question Does anyone know how to prevent the headlights from coming on when unlocking??
I was camping this weekend and I couldn't find a way to turn off the headlights coming on when I was unlocking my Jeep. It was flashing the next campsite. The best I could do was remove the lights from flashing when I locked it.
NOTE:: If you lock your car with the remote key FOB, and then try to unlock manually with the key, the alarm will sound and the light will come on
Old Jun 27, 2012 | 07:26 PM
ccgagnon's Avatar
Default EVIC Link
I found this link when searching for EVIC programming on Google: Jeep Grand Cherokee WK - Electronic Vehicle Information Center (EVIC) . I do not know much about EVIC programming. But it interests me.
Hope this helps,
Old Jun 28, 2012 | 06:16 PM
Rooster76's Avatar
Hope this helps,
It looks like it would be called "Illuminated Approach" in the EVIC. Mine doesn't have EVIC but maybe I can talk my dealer into changing it later. Thanks
Old Jun 28, 2016 | 01:40 PM
mmm2m8r's Avatar
Default Very useful free programming without the 900$ Uconnect
Thanks for this info. The 900$ option for Uconnect and the programming ability thru that was not needed. Reset 2016 Unlimited AEV JK3.5 to not chirp on lock. That would have been the only reason to add the Uconnect with EVIC programming feature. 900 bucks will buy something more useful. Bravo!
