Powerstroke.
I have a noise at about 2500 rpm in gear not valve chatter. It sounds like exhaust on right front right under passenger side feet. Also in neutral(6speed) if I rev it lightly it sounds like a powerstroke diesel at first but then gets to a normal sound. Any thoughts. Banged on heat shields no noise got under it with a flashlight no cracks but I can't see the manifold.
Common issues on these motors: 1) exhaust manifold leak. 2) loose heat shields. 3) pinging, or spark knock. You need to explain and pinpoint the sound a little better. Does it do it when motor is cold and hot, under load etc.
Thanks. OK, it happens when its warm, when Its under a load in 2,3,4th gear at about 2500rpm. Sounds like valve chatter but from under the glove box area, or where passengers feet go. The diesel sound is when its not under a load in my driveway and warm just on the initial tap of the gas it goes away after the rpms go up. Its hard to explain other than it sounds like a powerstroke.
I never use 87 I only use 89 and it does sound like an octane ping. Should I go up to a higher octane than 89?
