Removing the Doors - No bolt?
Originally Posted by zking1776
I got my Jeep in June '08, took the doors off July '08. The nuts never went back on. Makes for no brainer door removal. Not much concern with doors staying on in a car wreck. Most cases they get smashed in preventing them from opening anyway.
I am in agreeance to zking, ive been a Firefighter for 3 yrs and an EMT for 6 years, I have never seen a door opened by a push button handle being hit by another car. on that note if there is enough force to press that little button then that means there was signifigant force over a large area which means you will have a very large dent, and probly alot of passenger compartment intrusion.
which then means you probly wont even be able to get the door open, thus thank god for FF and the jaws of life.
As for the rollover the rotating motion would not pull the doors off because of the latch and seal. Where as if the doors get forced open by any givin means the doors will be ripped off when the hit the ground so therefore nuts or not they are coming off. so that is my conclusion that having the nuts to not have door nuts is not that much of a risk unless you are afraid they will get jacked!!!
Nuts don't do anything except make it a little harder for someone to steal your doors. I didn't know that the doors came off of my jeep when I bought I simply saw that it was easily removed with the two bolts and the strap and wa la it was off. I don't see why yours is so hard to get off I would try opening the door to 90 degrees and then lifting up I noticed that sometimes some angles are easier to remove the door with.
Okay. I've tried cans of WD-40 and PB Blast. I tried the floor jack and 2X4 method. Had the suspension extended a few inches and still nothing! I'm clueless and stuck with doors on a sunny 85 degree day. Grrrr!
Still under warranty? Then take it to the dealer and have them do it. Stop screwing around with it if you can't do it.
(Eat your Wheaties every morning?) Jus' sayin.....
What I had to do was get a 4" long 3/8" rachet extension, stuck it in the hole and rapped on it with a hammer. The pin in the door is a pressed in pin, and will move out somewhat from the door side of the hinge. The door will then come off and you will need to clean off the old grease from the pin before putting your door back on.
I would recommend having someone help you the first time. Make sure you have the wire disconnected and the strap removed. nothing like getting it off the hinges and realizing you are still attached. The doors can be a little awkward and difficult to get a good handhold on. One last thing, be careful with the limiting strap removed or you will become a member of the "dimple mod" group.
