Transmission fluid ?
Old Jun 2, 2010 | 12:25 PM
Xtreme545's Avatar
Default Transmission fluid ?
Okay so I bought the allens and bottle pump to change my transmission fluid today. I went to the dealership and was going to buy the mopar brand fluid, but they want about 23 dollars a quart for it, that's crazy! What is a good fluid to buy at an auto parts store that's decently priced and performs well in manual transmission?
Old Jun 2, 2010 | 12:47 PM
jason0341's Avatar
I use Valvoline ATF+4 Full Synthetic. For use in all Jeep and Chrysler vehicles.
Old Jun 2, 2010 | 12:53 PM
Xtreme545's Avatar
The valvoline ATF +4 is safe for the jeeps syncro's?
Old Jun 2, 2010 | 01:31 PM
jason0341's Avatar
WHOOOOAAA! Nevermind bro, I see you have a 6spd. Sorry for the comfusion, I didn't read that ATF+4 is automatic transmission fluid.
Old Jun 2, 2010 | 01:47 PM
jonboy's Avatar
Don't use atf+4 in your 6 speed. The only fluid compatible i found is pennzoil synchromesh manual transmission fluid. There may be others, you just have to go to a parts store and read the bottle to see if it meets spec for ms9224.
Old Jun 2, 2010 | 01:51 PM
Bosox5's Avatar
Veteran: Coast Guard
lol that would of been bad news..haha. Like said Pennzoil has it, check out your local auto parts store. Stealership is always a rip off!
Old Jun 2, 2010 | 02:49 PM
RevyJKU08's Avatar
Perfect....finally got an answer as I will be changing my Manual Tranny fluid this month myself. I was searching for a compatible fluid with no luck till now!
Old Jun 2, 2010 | 03:00 PM
Arrogantbastard's Avatar
Have fun changing the fluid. If you are dropping the pan, there are about 2 bolts that area a pain in the ASS!!!!! One was so difficult to get back in (the proper way would be to remove the exhaust) I just left it out all together!!! LOL... No problems at all running one bolt short.
Old Jun 2, 2010 | 03:04 PM
ronjenx's Avatar
Easy mistake to make. The term "Transmission Fluid" is usually reserved for automatic transmissions.
Old Jun 2, 2010 | 03:05 PM
jonboy's Avatar
Manual transmission doesn't have a pan.
