Will this work? Ignition key question
Old Jun 19, 2016 | 06:26 AM
Soilsample's Avatar
Default Will this work? Ignition key question
Hello all,
i bought my 07 jk used with only 1 key.
Can I buy a couple of non-chip keys and copy my original, then hide the original key under the steering wheel housing?
I understand that it would eliminate theft deterrent.
But would it work?
thanks!
Old Jun 19, 2016 | 06:55 AM
evoviii2jk's Avatar
Originally Posted by Soilsample
Hello all,
But would it work?
thanks!
I do believe this will work. I know on my evo this is what they wanted to do for remote start
Old Jun 19, 2016 | 06:56 AM
Wrangled's Avatar
Sure, the non chipped key will get you into the Jeep, but it will not start it. So having a chipped one inside will work.
Old Jun 19, 2016 | 07:29 AM
Soilsample's Avatar
Thanks for the input gents!
Old Jun 19, 2016 | 10:00 AM
16FW's Avatar
I don't know about an '07, but on my '15, if I unlock the doors with a non-chip key, the alarm goes off, until I push the open button on the key with a chip. Annoying, but at least it gets you in to get the right key.
Old Jun 21, 2016 | 08:36 AM
Grant09's Avatar
This will be the same on the '07. It'll set off the alarm every time.
Old Jun 21, 2016 | 08:57 AM
MavisJk's Avatar
If you use the key fob to lock the doors you have to use it to unlock them or the alarm will go off. If you lock the door with the key manually from the outside you should be able to manually unlock it without the alarm going off. Correct me if I'm wrong but that's how its worked on the two cars i had before my Jeep.
Old Feb 15, 2021 | 04:51 AM
Jarrett Vardaman's Avatar
Default Lost Key
I apologize I’m a few years late to the game, but the time has finally came. I only received 1 key from the dealer with my JK. I finally managed to lose it, presuming in a driveway covered in snow. I just learned the wonders of JScan few months ago, and have been wanting to make a new key... but of course haven’t yet. How should I go about getting a replacement key/programming..? I can have a locksmith make a new key for me, will that allow me to turn the ignition on to be able to see the pin and program the key? Or does the key I’m using have to be pre programmed before hand i.e. the one I lost.. I’m open to any suggestions. Thanks!
Old Feb 15, 2021 | 05:14 AM
karls10jk's Avatar
Just from my experience with the Jscan app and looking at that piece of info, I'd think if you can get the ignition turned on then the program would be able to retrieve the pin from the computer. I had my local home depot cut my key- it was free. Even if it wasn't , I'd happily pay their $3/key to have it cut. There's nothing special with the cut so it wasn't an issue for them.
Old Feb 15, 2021 | 10:33 AM
wascallywabbit7's Avatar
My 08 came with only one key, I did the key hide under the shroud with black non-chipped keys until i realized i could program my own keys with Jscan.
