Jeep Wrangler JK: Air Intake Review and How To
Performance intake systems are made by many different manufacturers. If you're ready to purchase one but unsure of which will be the best for you, you've came to the right place. This article compares and contrasts many of the popular intake systems available for the JK today.
This article applies to the Jeep Wrangler JK (2007-Present).
Air intakes reduce engine intake temperatures by moving the intake opening away from the engine's heat. Reduced engine temperatures creates a denser air intake charge, which combines with more fuel to generate more power. Performance air intakes use a high flowing synthetic filter and an aluminum or polyethylene tube. These materials are constructed with smooth bends to reduce restriction and keep intake flow high.
Table of Contents
How to Install an Air Intake
Materials Needed
- Flat head screwdriver
- Ratchet
- Extension
- 15mm socket
- 10mm socket
- 4mm Allen wrench
This guide is based off the K&N cold air intake installation.
From 2007 to 2011, the Jeep JK used the 3.8 liter engine. The JK now uses the 3.6 liter Pentastar engine. Although the steps are similar for intake installation, the locations of bolts and electrical connectors is different. These differences will be highlighted during the guide.
Step 1 – Disconnect negative battery cable
Use your 10mm socket and disconnect the negative (black) battery terminal. Refer to the article How to Replace Battery.
Step 2 – Remove your engine cover
The engine cover needs to be removed for access, pop it off and set it aside.
Refer to the article How to Replace Camshaft Position Sensor for detailed instructions. This step is not required for the 3.8 liter engine.
Step 3 – Remove the air intake tube
Start by removing the two bolts holding the intake tube to the air shroud. Remove the rubber line from the intake tube by pulling it out of the tube grommets.
Loosen the worm gear hose clamps at the air box and throttle body with a flat head screwdriver. Pull and twist the intake tube off the throttle body, but be careful as the air inlet temperature sensor connector is still attached. The sensor is located on the left side of the intake pipe near the throttle body. Disconnect the sensor by squeezing the flexible tab on the connector and simultaneously pulling the connector away from the sensor. Twist and pull the intake tube off the air box.
On the 3.8 liter, the I.A.T. sensor is located on the right side of the intake tube near the throttle body. The connector style is different. To disconnect it, slide the red locking tab up and squeeze the flexible tab while pulling the connector away from the intake tube.
Step 4 – Remove the air filter housing
Disconnect the crankcase rubber vent hose from the plastic vent tube. Carefully pull and twist the rubber off the plastic, then lift up and remove the air box.
On the 3.8 liter engine, the crankcase hose connects to the air box. Once it's removed, loosen the clamp holding the intake tube to the throttle body, and pull upwards on the air box to dislodge it from the mounting grommets.
Step 5 – Install the new air filter box
This step will vary by manufacturer, as each uses their own style of air box. Start by removing the bolt connecting the air box mount bracket to the inner fender. Also, remove the bolt that secures the radiator to the core support. Install the brackets, lid, and trim to the new heat shield. Leave off the top lid for now. Place the heat shield into the vehicle and tighten down the mounting bolts. This includes the two bolts removed from the air box mounting bracket and radiator core support. Install the new air filter into the air box and secure it with a hose clamp. Install the air box cover lid, making sure the lid mounting brackets are correctly positioned to create an air tight seal in the air box.
If you have a 3.8 liter engine, you'll need to remove both bolts from the air box mounting bracket and the power steering reservoir bolt. K&N also has you remove a bolt to the right of the power steering pump pulley to mount a bracket.
Step 6 – Install the new intake pipe
Install the new hose onto the air box and throttle body. Secure the hose to each with hose clamps. Before installing the new pipe, you'll need to screw the new vent fitting into the intake tube and remove/install the air temp sensor. The air temp sensor slides into a rubber grommet. Gently twist/pull it from the factory intake tube. Applying a small amount of Vaseline to the rubber grommet makes installation easier. Slide the new vent hose onto the vent fitting. The new intake may no longer have locations for the two air shroud mounting bolts. Zip tie the coolant overflow hose to a nearby component to achieve a factory style route if no new mounts are included. Now install the intake pipe into the air box and throttle body and tighten down the required hose clamps. Re-connect the crankcase vent hose to the vent tube and the I.A.T. sensor to the electrical connector. Finish the installation by re-installing the engine cover and re-connecting the negative battery cable.
Remember to re-install the power steering reservoir pump bolt for 3.8 liter engine owners.
To test for leaks, first start the engine. Listen for any hissing noises around the intake piping. If you have propane available, spray some around the intake tube connections. Rising engine RPMs while emitting propane indicates an air leak.
Air Intakes Review
An air intake is one of the most common upgrades done not only on the Jeep JK, but almost any motorized vehicle you encounter. This is for good reason. The intake is easily accessible and most factory intakes are made from bulky plastic that wind throughout the engine bay. Aftermarket intakes bump up the quality and slim down the bulkiness by using aluminum and other materials to create smooth bends and larger openings. The result is a small increase in horsepower, throttle response, and even fuel economy. An added bonus is the sportier sound that emits from the intake filter during spirited driving. There are even intakes available specially designed for extreme off-road expeditions.
Redrock |
Spectre |
Volant |
Banks |
K&N |
AEV | |
Price |
$180 | $150 | $355 | $300 | $310 | $400 |
Size |
3" | 3" | 3" | 3" | 3" | 4" |
Performance |
5-10 HP | 5-10 HP | 5-10 HP | 8 HP, 11 ft/lbs Torque | 5-10 HP | 5-10 HP |
Lifespan |
Reusable filter | Reusable filter | Reusable filter | Reusable filter | Reusable filter | Reusable filter |
Warranty |
1 year | 90 days | 4 years/100,000 miles (limited) | 5 years (limited) | 1 million miles (limited) | 1 year |
Best Quality: Volant
Best Value: Redrock
Redrock
Price – $180
Size – 3"
Performance – 5-10 HP
Lifespan – Reusable filter
Warranty – 1 year
The Redrock intake is a great intake for the JK owner looking to save cash while gaining some horsepower and increase engine intake noise. It uses a reusable mesh filter and aluminum intake tube. No computer tuning is required after installing this intake. Recommended for its low price point and basic but functional design.
Spectre
Price – $150
Size – 3"
Warranty – 90 days
Spectre offers the lowest price in the JK intake market, but also offers the shortest warranty. The intake uses an aluminum tube and a reusable low restriction filter that is easy to replace. Spectre filters can be found at large automotive parts stores such as AutoZone. Recommended if price is your number one buying determination.
Volant
Price – $355
Size – 3"
Warranty – 4 years/100,000 miles (limited)
The Volant intake system uses a polyethylene air box to insulate the incoming air for a cold intake charge. The intake piping is made from the same material, allowing bends that cannot be duplicated by aluminum. Volant states their filter is the most revolutionary on the market, filtering 99.97% of incoming air. Recommended for JK owners wanting looks, quality, and performance from their intake system.
Banks
Price – $300
Size – 3"
Performance – 8 HP, 11 ft/lbs Torque
Warranty – 5 years (Limited)
Banks intake systems features larger intake ducts and have the results of their work made available to the public. A 64% increase in airflow and almost 10 horsepower gain is made on the 3.6 liter engine. Banks includes a resonator on the intake to reduce the drone found on some other intakes. Recommended for its quality and proven results.
K&N
Price – $310
Size – 3"
Warranty – 1 million mile warranty (limited)
K&N is one of the first names thought of when intake systems are mentioned. Starting in 1969, K&N is now the world's leading manufacturer of washable performance intake filters and intake systems. K&N intakes are flow and dyno tested to ensure improvements in power and provide a long service life. Recommended for the brand's reputation and industry leading support.
AEV
Price – $400
Size – 4"
Warranty – 1 year
AEV is a specialist company for the Jeep Wrangler. Their engineering is not found else where with designs such as the AEV Hemi conversion kit. The snorkel is no different. The design utilizes the stock air box and mounting locations for easy installation. Polyethylene construction ensures a trouble-free service life. Recommended for any JK owner that faces deep water during their travels.
Related Discussions and Sites
- Cold Air Intake - JK-Forum.com
- Cold Air Intake Kit - JK-Forum.com
- Air Intake Users Only - JK-Forum.com
- K&N Air Intake - KNFilters.com
- Volant Air Intake - Volant.com
- AEV JK Snorkel Intake - AEV-Conversions.com
