Coax cable
Old May 30, 2012 | 04:53 PM
arjeeper's Avatar
Originally Posted by donnie
If there is a radio shop that sells ham equipment, like HRO, near you
try there and tell them what you are looking for.
This is a good call. Avoid crappy braid el-cheapo coax.
Old May 30, 2012 | 06:59 PM
JK-jeepit's Avatar
I would go with something like this.
h ttp://www.dxengineering.com/Parts.asp?ID=5422&PLID=239&SecID=127&DeptID={7C0A8 FE1-F72C-4346-916E-8AA93CD2A66B}&PartNo=DXE-8XDU018
Old May 31, 2012 | 06:40 AM
Rooster76's Avatar
If you need CB stuff it is a good idea to go by a truck stop. They seem to have anything you will need if your not too picky. Fry's and Radio Shack are good places to look for CB stuff too. Of course Amazon is king.
I would make sure both ends are male before you buy. Sometimes you can find coax cable that is just an extender male/female.
18' is what firestick recommends using for some technical reason. I'm sure 9' would work well too but I would stay away from other sizes if you can.
Originally Posted by Nico4x4
Would it be fine if I run a regular 16 gauge wire to ground?
I would go with a larger 10 gauge stranded wire. You can get it by the foot at Home Depot/Lowes. I personally used 12 gauge and it seems to be working. 12 is the minimum that the fire stick tech section recommends using. I did a write up on how I grounded mine here -->https://www.jk-forum.com/forums/jk-w...2012-a-231369/
Old May 31, 2012 | 09:43 AM
Nico4x4's Avatar
Perfect thanks! By the way I love the write up! I'm going to do everything like you did! Especially the way you mounted your CB, it's friggin genius!
