Fender/hood antenna mount
Old Jan 7, 2013 | 05:21 PM
Davearmstrong's Avatar
Default Fender/hood antenna mount
I have been looking for a aftermarket antenna mount for the driver side hood/fender. I have only found 1 and its $25 plus shipping which is $25, I can't justify spending $50 on a antenna mount. I can't mount it on the tail gate as I took the spare off and put a warrior plate so all the factory hole mounts are gone.
Has anyone found a cheaper mount or DIY from like Home Depot or anything. I'm most likely going to have to fab one up on my own but if I could find one for a decent price that would work to.
Thanks for your help
Old Jan 7, 2013 | 05:42 PM
JKJeepJunkie's Avatar
They make one that mounts to the existing tailgate hinges i think i seen it on quadratec or extreme terrain
Old Jan 7, 2013 | 05:55 PM
I can't mount one there cleanly because I have covered the holes in the tailgate with a warrior plate.
Has anyone purchased or made a fender cb antenna mount?
I have found one on right channel radios but its $50 with shipping which is a lot of money for a mount. Unless you guys think other wise.
Old Jan 8, 2013 | 04:52 AM
jeimep's Avatar
I made one and mounted my antenna on the rear corner of the tub. Granted I already had holes there from a wildboar roof rack but it worked nice and looks clean. I ran the cable right in behind my taillight.
Old Jan 8, 2013 | 05:09 AM
tslewisz's Avatar
AFAIK, there is no fender/hood mount specifically made for a JK. Whatever you find will probably have to be modified, like this guy:
https://www.jk-forum.com/forums/jk-c...0/#post3099805 Nice install.
I think it'd be pretty vulnerable up there going through brush, too, but that's your call. You CAN add a piece of angle above your Warrior tramp stamp, like this:
Or you could strip off the plastic condoms on your tailgate hinges and add a small bracket there.
Old Jan 10, 2013 | 05:40 AM
Yrjan's Avatar
Got a flat mount and bent it in half at a 90 degree angle. Ran the coax through the hole that the rear washer line goes through. Looks clean, works great. Hope this helps. (Mount was $8.00 at the local Ranch and Home store)
ID:	407800   Click image for larger version
Old Jan 10, 2013 | 02:15 PM
JK-UTE's Avatar
Nice looking mount. Seems to be what the op was looking for
Old Feb 6, 2013 | 09:19 AM
JK Pleepleus's Avatar
Was looking for mounting options myself, and found that RightChannelradios.com has a Jeep JK specific mount for $25 and shipping is $6. I might go this route, but you could probably modify any fender style mount just check this one out to see how to bend it.
